[< Previous 29 30 31 32 33 34 35 Next >]
Bluebird Nomad brakes 02
LittleFireyOne 2011/2/20 5:34 Tell a friend
805 1 0.00 (0 votes)
Top view. What is needed for this to work is:
- 910 BB S1\S2 bolt on disc hub - GC22 Nomad Vented rotors (250mm) - GC22 Nomad calipers - 7mm spacers to align caliper with disc (measure yourself, I will be double checking before I get the spacers made cos I grinded the bracket on one to get it to stay tight on the sunny strut. Now it will have to be milled true and the corresponding size spacer made for that side - shorter mounting bolt - modify banjo fitting on caliper or get new lines with round banjo
I know that you can just use R31 vented rotors and calipers but I found it amusing that these parts I had already wasted money on happen to fit with minor work and wont interfere with the wheels like the sunny attempt was coming close to. |
| Poster |
Thread |
| LittleFireyOne |
Posted: 2011/2/20 5:37 Updated: 2011/2/20 5:37 |
No life (a.k.a. DattoMaster)   Joined: 2005/8/27 From: Townsville, Qld Posts: 2776 |
 Re: Bluebird Nomad brakes 02 Also since i threw out the nomad dust shield I don't know if it would fit so you have to hammer the dust shield to stop the rotor rubbing.
