Main : Members : rally-a-coupe Radiator
[<   Previous  13  14  15  16  17  18  19  Next   >]
Radiator
RadiatorPopular
Submitterrally-a-coupeMore Photos from rally-a-coupe   Last Update2003/9/20 21:04    Tell a friendTell a friend
Hits3332  Comments4    0.00 (0 votes)0.00 (0 votes)
another shot of my new radiator
rally-a-coupe
Posted: 2004/5/3 10:44  Updated: 2004/5/3 10:44
 Re: Radiator
RADIATORS WHAT SORT OF TEMP DO YOUR RADIATORS COOL YA TO PREF ON TRACK OR HARD PUNISHMENT FOR TIME PERIODS
converted
Posted: 2004/5/3 10:54  Updated: 2004/5/3 10:54
 Re: Radiator
Its not really the lack of water cooling that overheats an A series on the track...its the oil which gets too hot and can actually boil. Yours is a good sized radiator but you'll need to get an oil cooling system for track work.
dattodevil
Posted: 2004/5/3 11:06  Updated: 2004/5/3 11:06
 Re: Radiator
should do the trick I think, What are you using in the way of an oil cooler?
Posted: 2004/5/3 16:08  Updated: 2004/5/3 16:08
 Re: Radiator
The radiator should keep the engine at the same temp as the thermostat: 160-degree or 180-degree depending on which thermostat you have. The 180-degree is generally best for street (higher temp for economy, but low enough to run a 7-lb cap).
