Main : Mechanical : Engine E15 dizzy in A14 block (3)
[<   Previous  1091  1092  1093  1094  1095  1096  1097  Next   >]
E15 dizzy in A14 block (3)Popular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2011/6/16 5:59    Tell a friendTell a friend
Hits1887  Comments1    0.00 (0 votes)0.00 (0 votes)
fits in just fine. This is the limit of ANTI-clockwise rotation before the hold down bracket hits the block.
See prev photo
Posted: 2011/6/16 6:06  Updated: 2011/6/16 6:06
 Re: E15 dizzy in A14 block (3)
You don't need to modify the dizzy casting to install in an A-series. Fits in just fine.
Limit of ANTI-clockwise rotation (this photo):
Limit of clockwise rotation:
There is plenty of room in a 1200 for any position in-between.
If you try to line up the cast-in hold-down bracket, the vacuum advance hits the block:
You could create a Chevy-style "fork" hold-down bracket to secure the E15 dizzy.
Or you can drill, grind, cut and otherwise modify the E15 dizzy casting. See E15 Electronic Distributor Swap
