Main : Mechanical : Engine Double Valve Spring
[<   Previous  1042  1043  1044  1045  1046  1047  1048  Next   >]
Double Valve Spring
Double Valve SpringPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2011/7/2 2:35    Tell a friendTell a friend
Hits1543  Comments1    0.00 (0 votes)0.00 (0 votes)
Valve springs
Posted: 2011/7/2 2:41  Updated: 2011/7/2 2:41
 Re: Double Valve Spring
Can see there is a nice gap (0.013 inch) between the valve stem and the rocker. At TDC, numbers 1,2,3 and 5 should have this gap. At the other TDC, number 4 and 6,7,8 should have the gap.
Also you can see the Valve Stem Seal is in place in the lower part of the valve (can see the silver spiral-wound keeper) in between the coils). If it was up toward the top something is wrong.
