Main : Misc : Tech Section test fit 2
[<   Previous  494  495  496  497  498  499  500  Next   >]
test fit 2
test fit 2Popular
SubmitterwubbitsMore Photos from wubbits   Last Update2003/9/29 22:24    Tell a friendTell a friend
Hits4510  Comments10    0.00 (0 votes)0.00 (0 votes)
second view of the test fit
dattodude
Posted: 2003/10/3 13:07  Updated: 2003/10/3 13:07
 Re: test fit 2
In some ways..it certainly looks like a RWD..I know we already know it's from a 4WD U12.
But the manifold looks really similar, but notice that the thermostat housing on the front of the engine (take it easy 1200RC) is facing the other way..just like the FWD engines.
Interesting.
Chris
kegs
Posted: 2003/10/3 15:47  Updated: 2003/10/3 15:47
 Re: test fit 2
it looks like 1200rc has already had his dig at that housing
CYA-18T
Posted: 2003/9/30 4:16  Updated: 2003/9/30 4:16
Quite a regular
 Re: test fit 2
hay looks 2 me like your turbo is facing wrong way with the dump pipe 2wards the front of the car?
is this just a illusion?
L18_B110
Posted: 2003/9/30 6:07  Updated: 2003/9/30 6:07
 Re: test fit 2
yeah - must be a fwd motor? that won't make things easy for the engine mount on that side...
Bullitt
Posted: 2003/9/30 6:26  Updated: 2003/9/30 6:26
 Re: test fit 2
I didnt know there was a FWD C18DET motor
MadTimo
Posted: 2003/9/30 7:23  Updated: 2003/9/30 7:23
 Re: test fit 2
Yep, there certainly is it fits into EXA's and N13 pulsars....stuff like that
CYA-18T
Posted: 2003/9/30 9:41  Updated: 2003/9/30 9:41
Quite a regular
 Re: test fit 2
yeah it is a fwd motor al u have 2 do is turn the turbo around.. as fwd engine mounts will have 2 bee changed... so should work ok...
would of been easier job just 2 get a rwd motor...
wubbits
Posted: 2003/9/30 10:43  Updated: 2003/9/30 10:43
 Re: test fit 2
There is not much choice here in the states
as no Nissan here came with the CA18DET
the closest thing is a Pulsar fwd ca18de..
My engine came with the awd transmission..
but I think mounting it sideways would be
harder.. :)
Wubbits
flyby
Posted: 2003/9/30 11:38  Updated: 2003/9/30 11:38
 Re: test fit 2
Sorry fellas, not a FWD, its a U12 AWD
FWD use the U11 and U12 in most conversions, most fwd nissan boxes bolt up using a ca18de flywheel.
its only a matter of mounts and which way the exhaust faces, and in my opinion thats no great big deal.
1200rallycar
Posted: 2003/9/30 11:49  Updated: 2003/9/30 11:49
 Re: test fit 2
im guessing it wont, but i have to ask, did you try fitting it the other way to see if 4wd is possible?
would be interesting
i reckon once my ca18det conversion happens (eventually)
the next step would be 4wd
matbighat
Posted: 2003/10/2 5:46  Updated: 2003/10/2 5:46
 Re: test fit 2
Really doesn't matter if it's fwd, rwd or awd, because no det stock exhaust manifold will clear on a lhd car. At least the awd version has the intake plenum facing the right way, as some fwd motors face the opposite direction.
wubbits
Posted: 2003/10/3 11:41  Updated: 2003/10/3 11:41
 Re: test fit 2
actually the throttle body is interchangable
with the other side of the manifold..
I just swapped them..
Wubbits
