Main : Mechanical : Drive Train stumpy/CA bellhousing bearing replacement
[<   Previous  692  693  694  695  696  697  698  Next   >]
stumpy/CA bellhousing bearing replacementPopular
SubmitterjackMore Photos from jack   Last Update2003/10/10 0:37    Tell a friendTell a friend
Hits4298  Comments2    0.00 (0 votes)0.00 (0 votes)
When i was changing the bellhousing on the stumpy gearbox i noticed that this bearing needed to be replaced with a bigger outside diameter one.
feral
Posted: 2003/10/12 9:25  Updated: 2003/10/12 9:25
 Re: stumpy/CA bellhousing bearing replacement
H'mmmm have you checked your cluster size,
it may be bigger than yo think
You may have had a gearset replacement from a nother box?
ANGE
Posted: 2003/10/12 9:41  Updated: 2003/10/12 9:41
Does anyone have a diagram of the breakdown of the internals of the stumpy box? after splitting my box i found an extra piece on the floor (looks like a little cap of some sort).... and im buggered if i can see where it goes??
im into weight saving but this wasnt what i had in mind
