Main : Mechanical : Engine Carburetor screws
[<   Previous  847  848  849  850  851  852  853  Next   >]
Carburetor screws
Carburetor screwsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2012/1/27 7:47    Tell a friendTell a friend
Hits1733  Comments2    0.00 (0 votes)0.00 (0 votes)
should look like this. Don't buy one that is stripped/distorted
adameimran
Posted: 2013/2/19 8:39  Updated: 2013/2/19 8:39
 Re: Carburetor screws
what is actually this both screw funtion and how to adjust it. I have a VERY MINIMUM KNOWLEDGE ON THIS..
Posted: 2013/2/19 20:23  Updated: 2013/2/19 21:00
The function of the screw is to fasten the top to the carburetor. There is no adjustment, only tighten it enough to be snug.
Be sure you use the appropriate size flat screwdriver. Using one too small or a + screwdriver may damage the screw.
The other part is the Slow Jet. Screw in and tighten. It must not be loose. Do not overtighten. It does not take much torque to make tight.
For more information, see Carburetor Overview
