Main : Mechanical : Brakes Nismo mk63 calipers and b310 coilovers 2
[<   Previous  106  107  108  109  110  111  112  Next   >]
Nismo mk63 calipers and b310 coilovers 2Popular
Submittera12gruntMore Photos from a12grunt   Last Update2012/5/1 13:53    Tell a friendTell a friend
Hits2974  Comments8    0.00 (0 votes)0.00 (0 votes)
Nismo mk63 calipers,
b310 coilovers with b122/b110 upper pyros
Posted: 2012/5/4 1:51  Updated: 2012/5/4 1:51
 Re: Nismo mk63 calipers and b310 coilovers 2
Are they from A14 B310 (large strut) or A12 B310 (small strut)?
a12grunt
Posted: 2012/5/4 13:58  Updated: 2012/5/4 13:58
hey dd,
got them from japan so no idea.how do i tell from which b310?
when i compare to my 1200 spare struts,these struts are considerably beefier and of a larger diameter.
any measurements i could refer to?
cheers
Posted: 2012/5/4 18:04  Updated: 2012/5/4 18:04
That's and excellent way. Compare them to 1200 struts. Since they are larger and beefier, they are the large struts. The A12-powered B310 uses nearly the same struts as a 1200. Datsun struts only come in small 45mm or large 2" diameter versions.
a12grunt
Posted: 2012/5/5 1:37  Updated: 2012/5/5 1:37
thanks for info mate.
Anonymous
Posted: 2012/5/5 11:23  Updated: 2012/5/5 11:23
Measure the distance between holes where meets to steering arm, also diameter of the hole ball joint end will sit in- probably same as stanza /200b conversion mods required to fit if big strut tube diameter
Posted: 2012/5/5 20:42  Updated: 2012/5/5 20:43
Right, here's a comparison diagram. The measurements in parentheses
are for (45mm dia. strut) vs 2" dia. struts
a12grunt
Posted: 2012/5/6 5:31  Updated: 2012/5/6 5:31
They are the big strut.diamter is 51mm approx /thereabouts.
Hoping to get adjustable rods etc
thanks again guys for info
Lemonhead
Posted: 2012/5/7 9:20  Updated: 2012/5/7 9:20
That's exactly the info I was looking for, just looking at machining a set up for my new rally car.
Thanks!
