Main : Members : levey Short shifter fitted.
[<   Previous  7  8  9  10  11  12  13  Next   >]
Short shifter fitted.Popular
SubmitterleveyMore Photos from levey   Last Update2012/10/25 8:58    Tell a friendTell a friend
Hits3647  Comments7    0.00 (0 votes)0.00 (0 votes)
levey
Posted: 2013/1/21 10:35  Updated: 2013/1/21 10:35
 Re: Short shifter fitted.
I made this at home after looking at the kit for sale from Maddat, so Maddat would be the best place to try.
levey
Posted: 2013/1/6 7:23  Updated: 2013/1/6 7:23
Ok I finally drove the car with the short shifter in it. It took a while to get used to, changing from 2nd to 3rd felt like I had only moved the gearlever to neutral.
I am really getting to like short shift now, shifting from neutral to any gear requires only about 35-38mm of shifter movement, hell of a difference :)
Anonymous
Posted: 2013/1/6 12:29  Updated: 2013/1/6 12:29
Nice work less wiggle more fiddle time
levey
Posted: 2012/10/25 9:41  Updated: 2012/10/25 9:45
I moved the pivot point higher and shortened the gear lever aswell.
It still changes nicely but might take abit to get used to, if anything it seems a bit tighter in the shift.
When I get a chance to drive it properly I'll let you know.
Posted: 2012/10/25 9:37  Updated: 2012/10/25 9:39
Short-throw shifter looks good. How's it work, is it just as smooth?
Some guys make a short shifter by just cutting the shift lever shorter. But only by moving the pivot point does it make the throw/travel shorter -- as levey has done so nicely here.
levey
Posted: 2012/10/25 9:10  Updated: 2012/10/25 9:10
Had to make a new reverse light bracket due to the increased height of the shifter but all seems to be working well.
Without doing an exact measurement it looks like about 30% less shifting distance from 2nd to 3rd gears, not bad but didn't want to go higher as it wouldn't fit below the standard center console.
darrell32
Posted: 2013/1/21 6:26  Updated: 2013/1/21 6:26
Not too shy to talk
Where did you get this kit from? i need something like this to run a civic centre console.
