Main : Mechanical : Suspension 1200 strut tops in 120Y - lowering
[<   Previous  114  115  116  117  118  119  120  Next   >]
1200 strut tops in 120Y - loweringPopular
SubmitterL18_B110More Photos from L18_B110   Last Update2013/6/8 5:01    Tell a friendTell a friend
Hits2426  Comments5    0.00 (0 votes)0.00 (0 votes)
1200 strut tops in 120Y lower the car by 30mm. 120Y's shock mount is 25mm under the strut tower, and the 1200's is 5mm above. Ride height changed exactly 30mm.
need to cut the centre hole out from 80mm to 94mm diametre.
1200 studs are 8mm versus 120Y's 10mm, so you need washers underneath the nuts.
Cable_Tie
Posted: 2013/6/9 12:15  Updated: 2013/6/9 12:15
 Re: 1200 strut tops in 120Y - lowering
Correct.
Please disregard the ruler.
Please Note the size difference in studs.
L18_B110
Posted: 2013/6/10 1:36  Updated: 2013/6/10 1:36
that's already noted in the photo description...
Cable_Tie
Posted: 2013/6/8 13:00  Updated: 2013/6/8 13:02
B210 on Left
B110 on Right
Anonymous
Posted: 2013/6/8 13:21  Updated: 2013/6/8 13:21
Best bit is still looks stock with the rubber tops.
L18_B110
Posted: 2013/6/8 23:04  Updated: 2013/6/8 23:04
Cable_Tie, I've seen that photo - it's misleading. It's not the difference between the height of them while sitting on a bench that matters, it's the relative position the top of the spring seat underneath them that changes the ride height. You can't see that in the photo.
The 120Y top mounts the spring seat 25mm under the strut tower, and with the 1200 top mounts the spring seat is 5mm above the strut tower. So you get 30mm lowering, not the 1.5" (38mm) that photo suggests. It's more like 1&3/16"
