Main : Mechanical : Suspension 120Y leaf spring Instant Centres - low vs stock
[<   Previous  113  114  115  116  117  118  119  Next   >]
120Y leaf spring Instant Centres - low vs stockPopular
SubmitterL18_B110More Photos from L18_B110   Last Update2013/6/15 3:53    Tell a friendTell a friend
Hits1750  Comments0    0.00 (0 votes)0.00 (0 votes)
120Y leaf spring Instant Centre location - low vs stock
'L' length between front and rear spring mounts on chassis is 1140mm.
3/8th L = 427.5mm
= approx 97mm from front eye longditudinally.
Approximate IC locations are at the end of the tape measure.
Stock blue coupe on left IC is approx 80mm higher than the lowered yellow 2dr sedan on right due to a combination of lower RC and decambered front half of leaf.
Effect of lowering is less bind/twist on the spring due to the IC being both closer to the spring eye and the axle's roll axis being closer to horizontal.
