Main : Docs Flywheel & Gearbox bolt dimensions, A-engine
[<   Previous  316  317  318  319  320  321  322  Next   >]
Flywheel & Gearbox bolt dimensions, A-enginePopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2017/2/17 22:51    Tell a friendTell a friend
Hits4882  Comments0    0.00 (0 votes)0.00 (0 votes)
Engine Plate A15 pictured. Transmission bolt holes are on a 300mm circle
Flywheel is 271mm diameter (not including the ring gear)
* clutch mounting bolt holes are 27° apart from the kick pins, which are every 120°, on a 216mm circle. For diagram of this, see flywheel blueprint
