Main : Docs Flywheel clutch bolt dimensions
[<   Previous  316  317  318  319  320  321  322  Next   >]
Flywheel clutch bolt dimensionsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2017/2/17 23:00    Tell a friendTell a friend
Hits1404  Comments0    0.00 (0 votes)0.00 (0 votes)
For standard clutch pattern. Derived from flywheel blueprint
* Flywheel is 271 mm diameter (not including ring gear)
* clutch bolt holes are drilled on a 216 mm circle
* clutch disc surface is O.D. 180mm, I.D. 125 mm
there is enough room on the flywheel to machine it for the 200mm L16 clutch
