Main : Mechanical : Body and Interiors Seat Belts
[<   Previous  1271  1272  1273  1274  1275  1276  1277  Next   >]
Seat Belts
Seat BeltsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2016/4/12 23:28    Tell a friendTell a friend
Hits2562  Comments4    0.00 (0 votes)0.00 (0 votes)
2-door sedan floor retrofitted with 1977 Datsun 620 retractor seat belts
datsunbeginner
Posted: 2016/9/14 2:52  Updated: 2016/9/14 2:52
 Re: Seat Belts
Is the tongue on the 3rd point bolted to the same mounting point as the retractor? Or separate hole?
Posted: 2016/9/14 3:54  Updated: 2016/9/14 3:54
 Re: Seat Belts
Yes sir, I bolted it to the same bolt. In the Datsun 620 there are actually 3 mounting bolt spots (only two in the 1200)
datsunbeginner
Posted: 2016/9/14 5:09  Updated: 2016/9/14 5:09
 Re: Seat Belts
The reason I ask is because I am sourcing seat belts for my 1200 ute and 1200 coupe.
I noticed my 1200 ute has 2 mounting point spots only.
My 1971 Coupe however has 3 mounting point spots. 2 are the same as the ute, and the third is just above the back seat pretty far back near the end of the side windows. I think that is an usual spot since the seat belt would be blocking the view out the side window. I see in the tech wiki they changed this mounting point in 1972 models.
Posted: 2016/9/20 6:54  Updated: 2016/9/20 8:16
 Re: Seat Belts
Yes, the third bolt hole was an upper bolt hole
The 620 belts -- as I remember -- were designed for two lower bolts, but I could be wrong and perhaps they only used a single lower bolt like the late 1200 retracting belts
