Main : Members : 1200rallycar a15ett inj mock up
[<   Previous  41  42  43  44  45  46  47  Next   >]
a15ett inj mock up
a15ett inj mock upPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2004/1/7 12:42    Tell a friendTell a friend
Hits4520  Comments13    0.00 (0 votes)0.00 (0 votes)
u can see it
datsik
Posted: 2004/4/13 14:33  Updated: 2004/4/13 14:33
 Re: a15ett inj mock up
is this dude kissin the manifold???
or is he blowin air through a tube??
1200rallycar
Posted: 2004/4/13 14:50  Updated: 2004/4/13 14:50
kissing, this man knows true beuaty when he sees it
AFRacer
Posted: 2004/4/13 16:19  Updated: 2004/4/13 16:19
One small vaccuum line in the middle of the manifold goes to the fuel pressure regulator. Some of the other vaccuum ports are for power brakes and emissions junk which you won't need unless you're using power brakes. Also one vacuum line needs to go to the vaccuum advance on the distributor, and another needs to go to the blow off valve, wastegate actuators, MAP sensor, and any boost control or boost guages. Anything else pretty much gets plugged/not used. Then you've got electrical and water connections. Unless you have a GX head or a head that circulates water through the intake, I would suggest getting rid of all the junk on the bottom of the intake (EGR, temp sensor) and either plug up the holes or cut a metal plate to replace/plug that whole EGR/water piece on the bottom. You'll still need a water temp sensor for the ECU, so you can mount it somewhere else in the system. Then your injectors and your TPS (throttle positioning sensor) mounted to the throttle shaft will get hooked into the ECU as well. Fuel lines are easy, the big one is from the fuel tank, and the fuel pressure regulator is hooked into the fuel rail and gets hooked up to a return line back to the fuel tank. That's pretty much it for connections, but any aftermarket ECU you go with should explain how things get hooked up too. I would also suggest trying to replace that JOKE stock throttle body and find or fab something up a little bigger and port out the opening there (by the throttle body) on the intake as well. The throttle body I'm using is from a CA20E I believe and with minor mods it goes on easy and is way bigger. I can't wait to hear how it runs with twin turbos and injection!!!! KEEP US ALL POSTED and get that injection on there ASAP!!!
-Andy
AFRacer
Posted: 2004/4/13 16:24  Updated: 2004/4/13 16:24
Oh and don't forget about Oxygen sensor in the exhaust pipe, and air temp sensor will go in somewhere as close to the injectors as you want to put it (I used one of the vaccuum port holes on top).
1200rallycar
Posted: 2004/4/14 0:26  Updated: 2004/4/14 0:26
thanks for the info, i had sorta worked out a lot of that information piece by piece now, but its good to have it all in one
thanks, when i pay off the debts the current setup has accumulated for me ill be on the hunt for that computer, at least i only need fuel only computer now because i have a modified dizzy (boost retard)
1200rallycar
Posted: 2004/1/7 12:43  Updated: 2004/1/7 12:43
well my photo posted send yours to my email and ill post it if you like
any help on what any of these hoses or wires do would be greatly appreciated, is there a sunny manual that includes info on the injection stups???
[edit] not me in pic
B120dat
Posted: 2004/1/7 12:54  Updated: 2004/1/7 12:54
Datsun X-rated
kegs
Posted: 2004/1/7 13:12  Updated: 2004/1/7 13:12
wat the hell is he doing?
MadTimo
Posted: 2004/1/7 13:21  Updated: 2004/1/7 13:21
Get a grip man!!!!!
1200rc.....depending on what computer you use, you probably won't need half of those hoses and wires. Probably just one vacuum line for the computer (and maybe some others for things like boost guage etc. whatever else needs vacuum). And the wires should just be for injectors, and they may be a temp sensor or something in there.
rally-a-coupe
Posted: 2004/4/13 12:18  Updated: 2004/4/13 12:18
where can i get one of thoes intake manifolds ?????
Posted: 2004/1/7 18:22  Updated: 2004/1/7 18:22
Here is the Sunny diagrams showing the hoses and so forth:
http://datsun1200.com/modules/myalbum/photo.php?lid=2826
I can send the rest if it would help.
1200rallycar
Posted: 2004/1/7 22:14  Updated: 2004/1/7 22:14
yeah if you have anything that tells me what all those numbers mean (part names or whatever) it would be great
there is some pics of a factort injection on here and it uses hardly any of the hoses too, so im going to try to mimic that as much as possible i guess
1200coupe
Posted: 2004/1/7 22:53  Updated: 2004/1/7 22:53
1200rallycar,
if you are coming up to Canberra for the Summernats you can contact me and come past my place and see how my injection is set up.
Paul.
