Main : Mechanical : Fuel Injection B310 EGI vacuum hose diagram
[<   Previous  194  195  196  197  198  199  200  Next   >]
B310 EGI vacuum hose diagramPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2004/1/17 21:53    Tell a friendTell a friend
Hits4918  Comments1    0.00 (0 votes)0.00 (0 votes)
Early A14E
Posted: 2004/1/18 5:21  Updated: 2004/1/18 5:21
 Re: B310 EGI vacuum hose diagram
It looks like (not 100% sure):
A = (???) EGR valve
B = temperature-based vacuum switch
C = 14771-H9215 VALVE ASSY-VVT
D = 22670-N4700 REGULATOR ASSY-PRESSURE
The switch on top middle on the manifold (which green and yellow hoses connect to) =
14956-H7206 VALVE ASSY-SOLENOID EGR CUT
(?) One of the hoses on throttle body = ported vacuum (for distributor advance). It will be the one on the filter side of the throttle butterfly.
