Main : Members A15 turbo intercooler
[<   Previous  1409  1410  1411  1412  1413  1414  1415  Next   >]
A15 turbo intercoolerPopular
SubmitterDatsun100ATurboMore Photos from Datsun100ATurbo   Last Update2004/1/22 6:54    Tell a friendTell a friend
Hits4848  Comments19    7.00007.00 (1 vote)
Engine mounted with intercooler....there is not much room in the enginebay in a Datsun E10!!
Demojob
Posted: 2004/1/22 9:23  Updated: 2004/1/22 9:23
 Re: A15 turbo intercooler
WTF!!!!!!!!!!!! Front wheel drive????
matbighat
Posted: 2004/1/22 9:33  Updated: 2004/1/22 9:33
Yes sir, that's an e10 aka Cherry. You're wacky eyes didn't deceive you this time.
dattodevil
Posted: 2004/1/22 10:02  Updated: 2004/1/22 10:02
Quality of workmanship A++, nice job
AlcoholicA
Posted: 2004/1/22 10:22  Updated: 2004/1/22 10:22
thats a mad setup...i like it...wat datto is it in? cos the enigne goes east-west...i wonder...
Demojob
Posted: 2004/1/22 11:21  Updated: 2004/1/22 11:21
Isn't front wheel drive blasphamy????
Datsun100ATurbo
Posted: 2004/1/23 6:34  Updated: 2004/1/23 6:34
Yepp, this is a fwd Datsun E10 from 1974, comes stock with a A10 engine DIN 59hp...
It weights only 680kg so you don
1200rallycar
Posted: 2004/1/23 7:31  Updated: 2004/1/23 7:31
why is there 2 breathers on the rocker cover, did you modify it?
and how did you get the breather pipe out of the block, i tried on a spare motor today, hitting it with a hammer to loosen it but it just started deforming the pipe
Datsun100ATurbo
Posted: 2004/1/23 7:54  Updated: 2004/1/23 7:54
The rockercover is from a Datsun 140A Cherry and it comes with two breathers! The breather pipe from the block came out easily but sometimes they are stuck like as they were welded!!!
Demojob
Posted: 2004/1/23 8:37  Updated: 2004/1/23 8:37
to get the preather pipe out of the block I used a pair of Stilsons and a pair of pliers, I tunred the pipe with the stilsons and pulled it outwards with the pliers, and slowly it came out
Cheers
damo
2332owner
Posted: 2004/1/23 10:03  Updated: 2004/1/23 10:03
It's so clean! Love the work. If anyone hasn't checked out this guys website go give it a look... nice page with lots of buildup pics and information.
Datsun100ATurbo
Posted: 2004/1/23 10:33  Updated: 2004/1/23 10:33
Wait until you see the last years buildup pics that soon will be added to my homepage..... I have over 200 pics from the buildup of the turboenginesetup on the pic!!
2332owner
Posted: 2004/1/24 7:16  Updated: 2004/1/24 7:16
Sounds like me... about 200 pics of my buildup too but I've still got a long way to go on the body etc. Unfortunately I'm internet challanged so I can't figure how to make a website that I'd be happy with.
kegs
Posted: 2004/2/11 12:11  Updated: 2004/2/11 12:11
i was just looking through and saw stuff bout block breather do u take this out when u mount a breather in the rocker cover?
if so what do u plug it with or wateva u do ?
Datsun100ATurbo
Posted: 2004/2/11 13:35  Updated: 2004/2/11 13:35
I don
1200rallycar
Posted: 2004/2/11 13:38  Updated: 2004/2/11 13:38
still love to know how to get that breather out, i did try on a spare motor but just started to squash the bugger
B120dat
Posted: 2004/2/11 13:41  Updated: 2004/2/11 13:41
mine Met with a friend i call a hack saw i couldnt get it out either!
Dodgeman
Posted: 2004/2/11 13:53  Updated: 2004/2/11 13:53
I've removed at least three of the breather pipes using the method that i had described in an earlier post. No real problem with those ones. All were 1200 engines.
1200rallycar
Posted: 2004/2/11 13:55  Updated: 2004/2/11 13:55
was that the tapping with a hammer method?, thats the one i tried
anyway im going to bed, ill search for it later
cya fellas
Dodgeman
Posted: 2004/2/11 14:42  Updated: 2004/2/11 14:42
1200RC
If you were squashing it, then you were NOT tapping it.
Tap it with a soft hide or copper hammer if you can find one. Tap it all around in a circular pattern, you know, up, down, left, right blah blah. You are only trying to get it to move a little.
Once it has loosened enough to move it by hand, then wrap one or both hands around it, & work it slowly at first. [this is where i got into strife again] Work it in any pattern that includes most cardinal points of the compass while exerting some outward pressure. As it gets near to the end of its spigot you can get a little more frantic with smaller moves & it should come out right in your hand.
Well, it worked for me.
Datopower
Posted: 2004/2/12 0:22  Updated: 2004/2/12 0:22
YES this is EXACTLY what i have done before too. - Great description Dodgeman !
kegs
Posted: 2004/2/12 3:10  Updated: 2004/2/12 3:10
have any of u ever thought of heating the sorrounding area with a butane torch? i used this method to get the little cylindrical block out of my rear brake adjusters. and they were rusted bloody tight im sure it would work the same.
