Main : Mechanical : Suspension Broken_Radius_Rod_Mount
[<   Previous  435  436  437  438  439  440  441  Next   >]
Broken_Radius_Rod_MountPopular
SubmitterjackMore Photos from jack   Last Update2004/2/4 1:02    Tell a friendTell a friend
Hits3472  Comments4    0.00 (0 votes)0.00 (0 votes)
Had to remove the sway bar to get the engine in for a test fit and noticed this. Faaaaaaaaaaaaaaaarrrrr out. More work to be done on the ute.
jack
Posted: 2004/2/5 6:59  Updated: 2004/2/5 6:59
 Re: Broken_Radius_Rod_Mount
I have no idea really, but is a radius rod, a castor rod and a tie rod the same thing?
dattodevil
Posted: 2004/2/5 7:13  Updated: 2004/2/5 7:13
a castor rod and a radius rod is the same thing, can also be known as a control arm. a tie rod (end) is different
dattodevil
Posted: 2004/2/5 7:15  Updated: 2004/2/5 7:15
lucky you picked up on that. would not like that to come loose at 100kph
benny
Posted: 2004/2/5 7:24  Updated: 2004/2/5 7:24
no.............
radius rod & castor rod same as the pic posted.
tie rod and tie rod ends are for steering.
Posted: 2004/2/5 8:16  Updated: 2004/2/5 8:16
The mounts on my 1200 snapped off the frame (completely detached) ... twice. This was the side underneath the battery where the acid had weakened it. Surprisingly it didn't result in loss of control; still it's not a good thing.
