Main : Mechanical : Suspension Suspension Glossary
[<   Previous  434  435  436  437  438  439  440  Next   >]
Suspension Glossary
Suspension GlossaryPopular
SubmitterjackMore Photos from jack   Last Update2004/2/5 7:24    Tell a friendTell a friend
Hits4224  Comments8    0.00 (0 votes)0.00 (0 votes)
Please explain/correct/enlighten me...
jack
Posted: 2004/2/5 7:30  Updated: 2004/2/5 7:30
 Re: Suspension Glossary
Ok, time I went to school again and learn't some more things. Can someone set me straight on whats what?
1. is a/the balljoint.
2. is ???? The tie rod? What to play with to do a wheel alignment, yeah?
3. is the radius rod and/or the castor rod.
4. is the sway bar (I know that for sure).
5. is the lower control arm? Isn't it?
[edit] dattodevil is too quick for my slow old modem i think...
dattodevil
Posted: 2004/2/5 7:36  Updated: 2004/2/5 7:36
A control arm has two bushes on the inner part, i.e a bottom arm and a radius rod built into the same unit. that is where the confusion normally comes from.
dattodevil
Posted: 2004/2/5 7:28  Updated: 2004/2/5 7:28
1: steering arm and bottom ball joint
2: tie rod ends
3: Radius rod/castor rod
4: sway bar
5: bottom arm
Posted: 2004/2/5 8:31  Updated: 2004/2/5 8:31
Excellent idea, Jack!
#1 is also known as the "knuckle arm" (with ball joint attached to it)
#5 is aka "lower arm". Dattodevil, I think you mean a "lower a-arm". The 1200 one here isn't an "a" (two inner bushings), but a simple lower arm link.
Here are the official Nissan part names for these 1200 components:
1. ARM-knuckle (w/BALL JOINT ASS'Y-lower)
2. ROD ASS'Y-side
3. ROD-tension, front suspension
4. BAR-torsion, front stabilizer
5. LINK ASS'Y - transverse
rgrinder
Posted: 2004/2/5 8:44  Updated: 2004/2/5 8:44
1 Steering arm and lower ball joint
2 inner anad outer tie rod assembly
3 tension rod (castor rod)
4 stabilizer bar (anti sway bar)
5 lower control arm (transverse link, A arm)
dattodevil
Posted: 2004/2/5 9:10  Updated: 2004/2/5 9:10
As you can see, there is alot of names and descriptions for the same piece of hardware, some correct some not so. To be accurate the manufacturer has the only true description.
The desciption can change with locality, so if you are trying to find the right terminology go genuine or use the local lingo, but really it doesn't matter too much what you call it as long as the person you are talking to understands what part you are descibing.
dattodevil
Posted: 2004/2/5 9:18  Updated: 2004/2/5 9:18
try this link for another view
Nolathane
Cameron_Datto
Posted: 2004/2/5 9:49  Updated: 2004/2/5 9:49
Single Joint Spring Strut = Mac Pherson strut
