Main : Misc TURBINE WHEEL SHOWING BLADE CONFIGURAION
[<   Previous  6482  6483  6484  6485  6486  6487  6488  Next   >]
TURBINE WHEEL SHOWING BLADE CONFIGURAIONPopular
SubmitterferalMore Photos from feral   Last Update2004/3/9 13:22    Tell a friendTell a friend
Hits2561  Comments2    0.00 (0 votes)0.00 (0 votes)
This wheel shows the flat blade section the gas packet is directed against and the trailing blade area leading to gas discharge.
phunkdoktaspok
Posted: 2004/3/9 13:33  Updated: 2004/3/9 13:33
 Re: TURBINE WHEEL SHOWING BLADE CONFIGURAION
This makes it more visible then my pic.
Does back cutting involve machining down the lefthand side of the turbine or just actually thinning out the lefthand side of the blades? If its the latter wouldnt this lead to turbine failure?( ie, bits breaking off the blades)
Cheers Steve
feral
Posted: 2004/3/9 21:22  Updated: 2004/3/9 21:22
Material is taken of the end of the blade. This opens the blade discharge area, and changes the angle of discharge.
Increasing the housing clearance at the discharge area achieves much the same effect but efficiency drops of rapidly as clearance is increased.
