Main : Misc inlet
[<   Previous  6484  6485  6486  6487  6488  6489  6490  Next   >]
inlet
inletPopular
Submitter1200coupeMore Photos from 1200coupe   Last Update2004/3/9 6:26    Tell a friendTell a friend
Hits2886  Comments4    0.00 (0 votes)0.00 (0 votes)
cold air box detail
2332owner
Posted: 2004/12/15 23:54  Updated: 2004/12/15 23:54
 Re: inlet
Here's another shot of it with an explination and a lot more discussion:
http://datsun1200.com/modules/myalbum/photo.php?lid=3268
datman55
Posted: 2004/12/15 22:04  Updated: 2004/12/15 22:04
 Re: inlet
Great looking airbox...how does it seal at the top? Also, why the clear "flutes" at the back of the box? Wouldn't the engine start sucking air in through them when the car isn't moving?
1200coupe
Posted: 2004/12/16 1:02  Updated: 2004/12/16 1:02
 Re: inlet
The clear flutes at the back of the air box were designed to cool the inlet plenuim and there's no point in wasting useful cold air coming in from the front of the car. At idle they dont do much but once your moving they work. When testing this design I mounted a thermocouple to the wall of the plenium and I recorded inlet temps around 5 degrees cooler so the clear flutes/vents do a good job at cooling things down and preventing the air box from choking. A good flow of air is always available to cool the plenium when the car is moving.
Keep in mind that this car is very rarely sitting at idle in traffic and the cold air vents were designed with this in mind.
BACKFIRE
Posted: 2004/12/16 1:41  Updated: 2004/12/16 1:41
 Re: inlet
The perspex flutes do look rather special.
Basically you can't have a pressurized cold air intake for a NA car because your fuel measuring system won't like the variable pressures created when moving. Especially on a carby set up.
datman55
Posted: 2004/12/16 2:03  Updated: 2004/12/16 2:03
 Re: inlet
ahhhhh...great idea!
Looks like a pretty trick bit of gear..well done
