[< Previous 2665 2666 2667 2668 2669 2670 2671 Next >]
1 x 42mm weber install almost finished
evilsim 2004/4/3 4:38 Tell a friend
11392 5 10.00 (2 votes)
at last i purchased the linkage kit and manifold for this 42mm weber. went together very nicely although 2 important nuts were missing from the linkage kit so they need to be found. also fuel line hose missing at this point. cant wait. cheers to a mate for helping out heaps with it.
there were also 2 missing R - type pins to hold in various rods. apart from that the kit had everything.
the airfilter is missing from this pic but there will be a phat redline filter on there when its ready. not socks its a box air filter. |
| Poster |
Thread |
| Tommy |
Posted: 2004/4/4 4:05 Updated: 2004/4/4 4:05 |
Home away from home   Joined: 2003/7/4 From: Wamboin near ACT(canberra) Posts: 878 |
 Re: 1 x 42mm weber install almost finished i just bought a 42mm side draught weber 2!!!, how much was the manifold and all the other stuff, its goin on my 15 that i will be gettin in 2 and a half months so it will give me some time 2 organise it. Tell us what she goes like when u get her up and runnin!!!!
| Poster |
Thread |
| b310gx |
Posted: 2004/4/3 14:55 Updated: 2004/4/3 14:55 |
No life (a.k.a. DattoMaster)   Joined: 2002/7/19 From: sydney australia Posts: 1858 |
 Re: 1 x 42mm weber install almost finished you're also missing the thackwell rubbers which fit between the nuts & the carb.this allows the carb to move a little bit,as bolting webers solid to a 4 cylinder causes the fuel to froth up in the fuel bowl.sounds weird,but i did exactly the same with my first set of webers.when the problem was finally found all the smartarses gave me heaps.these little washers are rubber with a v cut into them,& there should be a little cup shaped washer to go between them & the nuts.thats why the studs are so long on the manifold.
| Poster |
Thread |
| evilsim |
Posted: 2004/4/5 0:47 Updated: 2004/4/5 0:47 |
Home away from home   Joined: 2003/11/30 From: Sydney.au Posts: 597 |
 Re: 1 x 42mm weber install almost finished it did come with the rubbers but i wasnt sure where they go. can you explain a little more and ill put them in the right place. I have used only 1 of them as a spacer. thanks for your help !
| Poster |
Thread |
| kegs |
Posted: 2004/4/3 14:19 Updated: 2004/4/3 14:19 |
No life (a.k.a. DattoMaster)   Joined: 2003/1/5 From: campbelltown (sydney) australia Posts: 1802 |
 Re: 1 x 42mm weber install almost finished how much did the webber set u back? im contemplating running one big dcoe on my s/c a15.
| Poster |
Thread |
| evilsim |
Posted: 2004/4/3 10:38 Updated: 2004/4/3 10:38 |
 Re: 1 x 42mm weber install almost finished hooray it works ! idles at over 2k as its still tuned for race in a L20b, not the A12 it is on. =]
