Main : Misc My Datsun 120Y 1978
[<   Previous  6383  6384  6385  6386  6387  6388  6389  Next   >]
My Datsun 120Y 1978
My Datsun 120Y 1978Popular
SubmitterAndreseduMore Photos from Andresedu   Last Update2004/4/15 19:39    Tell a friendTell a friend
Hits6338  Comments4    10.000010.00 (1 vote)
Nice car????
nzdattoman
Posted: 2004/4/30 5:53  Updated: 2004/4/30 5:53
 Re: My Datsun 120Y 1978
how much do they want for it ?
jaimecidpedro
Posted: 2004/4/15 23:54  Updated: 2004/4/15 23:54
Nice 120Y. Nice color too. If you lower your 120Y, it will look better, and and also(and more important too) will perform much better under cornering, straight speed, highway, all around.
You can use blocks in the rear, or decamber the springs , either or, or a combination of the 2(decambering 2 inches = a one inch block). The front, smaller spring(cut off) + cutting a section of the front strut will be the cheaper way, or else, coil overs if available.
Lowered, black wheels(that is a personal preference, I like black wheels)then, you can add wider wheels, 13X7 or 13X8.You can use 175 or 195 or 215 wide 50 series tires( there are better sizes, but unfortunately, only racing compounds). Your car would look tough, perform excelent, low center of gravity, and respect on the road. You want your 120Y to be swift, fast, and look like it means business, larger diameter on a 120Y will only make it akward, like a giraffe, make it tough, not langy.
I am jelous, look at those bumpers, you are lucky you never got the "park bench" US version bumpers.
Cool
___________________________
datsik
Posted: 2004/4/21 16:27  Updated: 2004/4/21 16:27
if not done right, lowering a car actually makes the handling worse. This is becauase the amount of "bump steer" increases. This causes the car to drive where it wants on bumpy surfaces.
Posted: 2004/4/21 16:38  Updated: 2004/4/21 16:38
Hmmm .... if you look at only the top half of this picture, it looks like a Jaguar.
matbighat
Posted: 2004/4/21 19:35  Updated: 2004/4/21 19:35
Needs some more agressive wheels, I think!
