Main : Misc Datsun 1k with sigma GE brakes
[<   Previous  6331  6332  6333  6334  6335  6336  6337  Next   >]
Datsun 1k with sigma GE brakesPopular
SubmitterDMore Photos from D   Last Update2004/5/13 12:37    Tell a friendTell a friend
Hits4593  Comments13    0.00 (0 votes)0.00 (0 votes)
This is the Sigma GE setup on my 1000.
229mm solid disks
sigma calipers and caliper bracket
datsun 1200 coupe hubs
datsun 1000 lines
datsun 1200 coupe master cylinder
etc.
D
Posted: 2004/12/8 2:22  Updated: 2004/12/8 2:22
From: under the Firmament LOL no twiglight effect BS
 Re: Datsun 1k with sigma GE brakes
Well I posted the bluebird diff and it has the drum diameter of the later bluebird drums and luckily a 240-260z alloy drums fit too.
I went for the sigma rotors for their larger size and thickness compared to 120y rotor and caliper. The sigma caliper is different Im sure as it accepts the thicker rotor from the sigma. I still havent found calipers that fit the vanette front end after searching far and wide. As I dont have the manuals or program to check for other possible calipers I can use for the vented vanette setup I cant proceed to find a better caliper.
I love how my b10 brakes now even after several bursts through the great ocean road.
The next step up is datomans1000 kit for those looking for vented disks unless someone solves the vanette caliper setup to alloy calipers.
pro-240c
Posted: 2004/12/8 7:00  Updated: 2004/12/8 7:00
i read that as the sigma calipers, sigma discs AND sigma brackets. is that correct?
pro-240c
Posted: 2004/12/9 2:37  Updated: 2004/12/9 2:37
yes? no?
D
Posted: 2004/12/13 4:00  Updated: 2004/12/13 4:00
Yes thats right they are larger and thicker than the 218mm 120y or 1200 212mm ones check the specs at pbr.com.au
the sigma rotors are 229mm diameter but the centre hole is 67mm so the 1200 coupe hubs need 3mm off to fit sigma rotors off the shelf. Also available are slotted ones!
pro-240c
Posted: 2004/12/13 4:56  Updated: 2004/12/13 4:56
cool, thanks
cabridgee
Posted: 2004/12/27 0:35  Updated: 2004/12/27 0:35
does the hub need to be drilled out? does the sigma caliper mount up without to much trouble?
D
Posted: 2004/12/28 3:33  Updated: 2004/12/28 3:33
The hub needs 3mm off the diameter to fit off the shelf sigma ge disks and the caliper brackets need to 3 of the holes re drilled about 5mm away from originals so the calipers miss the tie rods.
Dodgeman
Posted: 2004/5/15 12:00  Updated: 2004/5/15 12:00
Does anyone know the piston diameter in these calipers?
dattoman_1000
Posted: 2004/5/15 12:59  Updated: 2004/5/15 12:59
2 1/8"
D
Posted: 2004/5/19 12:37  Updated: 2004/5/19 12:37
Sorry a bit late steve with my reply.
Yes they are front calipers, caliper brackets and disks.
I hadnt been on the net for a few days and lost this thread I posted
For the weight of a 1k compared to sigma (500kg lighter at least) they work really well and are cheap to set up.
However Im still interested in the vanette setup with the larger vented disk but better and lighter calipers than the vanetter cast steel ones. I was thinking the camira or vl commodore vented alloy calipers but havent gone further with researching.
Well making brackets and other stuff takes time, knowledge, ability and..... well I have almost one of the metioned.
D
Posted: 2004/5/13 12:42  Updated: 2004/5/13 12:42
finally got a digital camera
the diff comparo is next I promised a while back about bluebird series 1 1967 diff with d1k diff.
phunkdoktaspok
Posted: 2004/5/13 12:50  Updated: 2004/5/13 12:50
Looks good.
Are they front or rear sigma calipers and bracket?
b310gx
Posted: 2004/5/15 8:00  Updated: 2004/5/15 8:00
these look like the calipers i used to use,which were off a 120y,with pbr brakes.they used the same pads as early sigmas.i used them in several cars & were always good.just in case you can't find a ge sigma.don't know if the disks were the same diameter.
