Main : Misc : Tech Section 1200 Shock Absorbers
[<   Previous  155  156  157  158  159  160  161  Next   >]
1200 Shock AbsorbersPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2012/11/1 7:14    Tell a friendTell a friend
Hits25268  Comments9    0.00 (0 votes)0.00 (0 votes)
56210-H1001 SHOCK ABSORBER KIT-rear (2) - Sedan
56210-H1825 SHOCK ABSORBER KIT-rear (2) - Coupe
56210-H1425 SHOCK ABSORBER KIT-rear (2) - Van (Wagon)
56210-G1025 ABSORBER KIT-SHOCK REAR (2) - Truck (Ute/Pickup)
gregw
Posted: 2010/2/23 8:47  Updated: 2010/2/23 8:47
 Re: 1200 Shock Absorbers
Hi, i just got an awesome deal at supercheap auto over here, special order shocks that a guy did not collect and sat on the shelves, i saw them which had a special price on them of $5 each down from $150 each, bought them both, remembered seeing this post that vw beetle shocks would fit on the rear of a datsun coupe, these shocks i bought were for a 67 - 75 vw, KYB gas a justs part number kg4520
Heres a link to a post i made on nzdatsun with photos but never got an answer back.
http://www.nzdatsun.com/forums/viewtopic.php?f=2&t=1083&sid=d1bdca6f253e5175eabfa3ba8d08605e
are these alright to use in datsun 1200 coupe? I also saw somewhere on here not to use gas shocks in the rear of coupe but to use oil shocks, is this correct
Posted: 2010/2/23 21:48  Updated: 2010/2/23 21:48
It is "alright" to use gas-filled shocks. What was previously said is that the original specification shocks (non-gas) will be less harsh and will help eliminate bouncing.
Gas shocks are primarily oil-filled, with a gas over the oil to help suppress frothing. But since they are under pressure, it makes the shocks stiffer than non-gas shocks. With most cars, with typical "soft" suspension, gas shocks tighten it up a bit (an improvement). But with Datsun 1200 already having stiff rear springs, making them even stiffer is not necessarily what you want.
gregw
Posted: 2010/2/24 8:15  Updated: 2010/2/24 8:15
would these Kg4520 fit the rear of the coupe, i cannot find info on the shock measurements
Posted: 2010/2/25 1:01  Updated: 2010/2/25 1:01
http://datsun1200.com/modules/mediawiki/index.php?title=Shock_absorbers
Specifications - Coupe
Stroke: 180mm
Max. Length: 440
Rebound: 68
Compression: 45
Posted: 2004/5/16 4:33  Updated: 2004/5/16 4:33
 Re: 1200 Shock Absorbers (Coupe)
Did you know that VW Beetle shocks fit the 1200 coupe?
KYB Part Number 343143:
1971-73 Datsun 1200 Coupe
1974-78 Datsun B210 Coupe
1970-74 Toyota Corolla wagon (starting 5/70)
1966 Volkswagen Type I (except 1200)
1967-70 Volkswagen Type I all
1971-77 Volkswagen Type I (except Super Beetle)
For more information on the rear suspension and shocks, see: Suspension Upgrades
Posted: 2004/5/16 4:35  Updated: 2004/5/16 4:35
 Re: 1200 Shock Absorbers (Wagon)
Koni still sells shocks for the 1200 wagon/van: Koni PN 80-1904.
Posted: 2004/5/16 4:42  Updated: 2004/5/16 4:42
 Re: 1200 Shock Absorbers (Sedan)
For sedans, we got a choice:
Gabriel Guardian (gas charged)
Monro-Matic Plus (gas)
Orca/BOGE
KYB Gas-A-Just
KYB GR2 Gas
Which is best?
Gabriel Guardian (gas shock) PN 81501 fits:
- 1200/B110 1971-1973 Sedan
- 200SX 1976-1984 (solid axle)
- 210/B310 1979-1982 all
- 510 1978-1981 exc. wagon
MONRO-MATIC Plus (gas) PN 33272:
74-78 B210
Orca/BOGE PN OR-27103x2 is 50/pair at classicgarage.com
KYB GR-2 Gas Shock: 343140 fits:
1971-73 Datsun 1200 Sedan
1976-82 Datsun 200SX all
1979-82 Datsun 210 all
1978-81 Datsun 510 exc. wagon
1974-78 Datsun B210 except coupe
1978-85 Mazda RX7 all
1967-74 Toyota Corolla exc. wagon
1973-74 Toyota Corolla SR5 all
Specifications:
ext. length: 20.75 inches
com. length: 13.39 inches
stroke: 7.36 inches
no dustcover
no rebound stop
comes with bump stop
upper mount: S1 (standard 3/8 inch O.D. stem bayonet mount)
lower mount: E2 (12mm I.D. x 32mm long) (Eyering with bushing and metal sleeve)
Length is measured from center of eyering to shoulder of stem
200SX and 210 also use KG4764A (Obsolete) use mounting kit C199:
1980-83 Datsun 200SX all
Specifications:
ext. length: 21.06 inches
com. length: 13.90 inches
stroke: 7.17 inches
no dustcover
comes with rebound stop
The RX7 shocks also come in KYB Gas-A-Just model KG4644A:
1987-89 Toyota Van (4 w/d)
Specifications:
ext. length: 21.34 inches
stroke: 7.95 inches
comes with dustcover
no bump stop
D
Posted: 2005/1/11 21:50  Updated: 2005/1/11 21:50
From: under the Firmament LOL no twiglight effect BS
Very nice information DD and also take note that you can get lowered versions of KYB for type 1 bettles and also GAB brand.
I used to have these lowered version shocks on my manx beach buggy and they where awesome. You can also get coilover shocks for the type 1 which I have never had but bettles stuff is good news for the datsun as they have the best aftermarket service of any car.
minitruckin
Posted: 2008/2/29 16:19  Updated: 2008/2/29 16:19
sweet... thanks guys all the information i need...... cheers.
