Main : Members bobs1200 engine
[<   Previous  1693  1694  1695  1696  1697  1698  1699  Next   >]
bobs1200 engine
bobs1200 enginePopular
Submitterbobs1200More Photos from bobs1200   Last Update2002/10/4 21:35    Tell a friendTell a friend
Hits11675  Comments8    0.00 (0 votes)0.00 (0 votes)
view from rt side removed master cylinder for carb clearance. I use the flintstone method for stopping.
jaimecidpedro
Posted: 2002/10/13 5:55  Updated: 2002/10/13 5:55
 Re: bobs1200 engine
Nice set up. I am looking to install duals in my A15 engine, and probably be forced to get rid of the brake booster. How is that work, just braking with no booster?
Let me know the way the brakes work in a boosterless car.
Jaime
Posted: 2002/10/14 4:16  Updated: 2002/10/14 4:16
 Re: bobs1200 engine
Usually, not very well. The master cylinder is a different size in a boosterless model, and if the booster stops working it takes a lot of pedal pressure to stop the car. You can test the effect this will have on your B210 (120Y) by temporarily disconnecting and plugging the booster hose with a spark plug or bolt.
The brakes in the 1200 have easy pedal effort due to the light weight of the vehicle. It doesn't need a booster. The B210 is 20% heavier and is about the borderline of where cars got boosters ... back then a lot of cars that were heavier did not have power brakes, so there is no real requirement. With the right size master cylinder it should work fairly well.
AlcoholicA
Posted: 2003/3/29 7:18  Updated: 2003/3/29 7:18
 Re: bobs1200 engine
hey dude i was wondering...on the b12's is the exhaust ports on the same side of the head as the inlet ports?
pitanando
Posted: 2006/4/23 11:46  Updated: 2006/4/23 11:46
 Re: bobs1200 engine
Allway
Posted: 2006/4/24 1:36  Updated: 2006/4/24 1:36
 Re: bobs1200 engine
by the way... how do you think in stoping the car?
Click the Previous link just above the picture to get the explanation. Also the picture before that.
converted
Posted: 2006/4/23 23:07  Updated: 2006/4/23 23:07
 Re: bobs1200 engine
both my race cars run unboosted and are great..better feel and brakes very well.
