[< Previous 120 121 122 123 124 125 126 Next >]
| Poster |
Thread |
| Dundee1000 |
Posted: 2013/3/23 0:43 Updated: 2013/3/23 0:43 |
No life (a.k.a. DattoMaster)   Joined: 2003/2/10 From: Freo Posts: 3318 |
 Re: mocked up engine nice Pipes...
| Poster |
Thread |
| simmodat1200 |
Posted: 2004/6/7 13:09 Updated: 2004/6/7 13:09 |
Home away from home   Joined: 2001/5/8 From: Adelaide, SA Posts: 196 |
 Re: mocked up engine Nice big ports. Yeah chrome not really that good for heat.
| Poster |
Thread |
| DatA15 |
Posted: 2004/6/7 13:13 Updated: 2004/6/7 13:13 |
Home away from home   Joined: 2003/9/25 From: Adelaide Posts: 594 |
 Re: mocked up engine looks nice and clean,
| Poster |
Thread |
| AFRacer |
Posted: 2004/6/7 13:34 Updated: 2004/6/7 13:34 |
Home away from home   Joined: 2002/3/7 From: Little Rock, AR Posts: 639 |
 Re: mocked up engine Yeah looks real good, but I've always heard the same thing about the chrome valve covers trapping in the heat. I'd say sell it to someone else and go with a nice powder coating instead.
| Poster |
Thread |
| kegs |
Posted: 2004/6/7 13:45 Updated: 2004/6/7 13:45 |
No life (a.k.a. DattoMaster)   Joined: 2003/1/5 From: campbelltown (sydney) australia Posts: 1802 |
 Re: mocked up engine yeah i heard the same but how good does it look, i havent even polished it. maybe ditch it for my a12 datsun one, maybe just adding one of them oil breathers will let the heat out enough???
| Poster |
Thread |
| feral |
Posted: 2004/6/7 14:27 Updated: 2004/6/7 14:27 |
Home away from home   Joined: 2002/5/1 From: Millgrove Vic OZ Posts: 985 |
 Re: mocked up engine Dont stress! Heat loss through the rocker cover is minimal. The whole engine is cooled by water and the oil lubricated bits should not get over 100C any way.
If unsure, fit an oil cooler, a good crankcase breather and then problem solved.
| Poster |
Thread |
| Razor |
Posted: 2004/6/7 22:16 Updated: 2004/6/7 22:16 |
Home away from home   Joined: 2003/8/26 From: Brisbane Posts: 867 |
 Re: mocked up engine Don't worry kegs I'll save you I'll sacrifice and swap my stock one for your chrome cover kidding.....
| Poster |
Thread |
| ddgonzal |
Posted: 2004/6/8 5:32 Updated: 2004/6/8 5:32 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: mocked up engine beefy looking exhaust header. What size are the primaries on those extractors?
| Poster |
Thread |
| kegs |
Posted: 2004/6/8 5:38 Updated: 2004/6/8 5:38 |
 Re: mocked up engine they are just over 40mm or around inch and three quarters.
| Poster |
Thread |
| wolki101 |
Posted: 2008/11/13 9:12 Updated: 2008/11/13 9:12 |
Home away from home   Joined: 2006/11/18 From: ACT Aus Posts: 940 |
 Re: mocked up engine yeah that chrome looks awesome. what if you just got a stock one polished up ridiculously so it looked like chrome? would that trap the heat the same or is it the actual chrome that traps heat?
| Poster |
Thread |
| bert |
Posted: 2008/11/13 9:39 Updated: 2008/11/13 9:39 |
No life (a.k.a. DattoMaster)   Joined: 2005/3/22 From: gold coast QLD. Posts: 1674 |
 Re: mocked up engine I,m with feral,and never had an issue with a chrome R/C.and too much heat!
Just more old wives tales.But i also always vent to a catch can as well.
| Poster |
Thread |
| Bandit_blues |
Posted: 2008/11/13 10:07 Updated: 2008/11/13 10:07 |
Home away from home   Joined: 2007/5/11 From: Lisboa-Portugal Posts: 470 |
 Re: mocked up engine Nice headers! I got one of those too for my gx head.
| Poster |
Thread |
| D |
Posted: 2008/11/13 12:07 Updated: 2008/11/13 12:07 |
No life (a.k.a. DattoMaster)   Joined: 2002/10/28 From: under the Firmament LOL no twiglight effect BS Posts: 10994 |
 Re: mocked up engine I always wanted to know if I could make a shorter version of the L series motor, unlike the L6 version they have a deeper skirt which adds much weight. In Europe the same type of deep skirt is known to be shortened for Fiat twin cams to reduce weight and use a dry sump unit. The A series does well without this deep skirt and it is still something Id be interested in theoretically playing with if the oiling was sorted using dry sumping. A possible 10kg could be removed which could come 5-10kg shy of an A series rather than 20. Of course an A series type sump will need to be made to suit and re-tapping for bolt threads and new engine mounts. Plenty of iron on that sucker to keep it all together.
| Poster |
Thread |
| A14force |
Posted: 2004/6/6 22:24 Updated: 2004/6/6 22:24 |
No life (a.k.a. DattoMaster)   Joined: 2003/12/3 From: Christchurch NZ Posts: 3707 |
 Re: mocked up engine I would lose the chrome rocker covers If I were you. They trap heat real bad and cause valveguide seals to go hard and stop sealing.
