Main : Misc Factory rod prep
[<   Previous  6093  6094  6095  6096  6097  6098  6099  Next   >]
Factory rod prep
Factory rod prepPopular
SubmitterDodgemanMore Photos from Dodgeman   Last Update2004/7/22 11:55    Tell a friendTell a friend
Hits3292  Comments6    0.00 (0 votes)0.00 (0 votes)
This is the factory recomendation, circa 1974
racer135
Posted: 2019/5/23 9:28  Updated: 2019/5/23 9:28
 Re: Factory rod prep
Dodgeman do you have the original book or just electronic snippets from it?
Posted: 2019/5/28 0:39  Updated: 2019/5/28 0:39
I'm sure Dodgeman has this book, as it is the common A12 factory serivice manual can be found for as little as $10 on eBay
Posted: 2019/5/28 3:31  Updated: 2019/5/28 3:31
been looking through my 1973 Factory Service Manual and after showing how to inspect the rods and their specs, it only says "repair and replace" . So maybe Dodgman used a newer FSM?
Or maybe this is not about factory prepping but about race prepping the rods. In which case it might be from the Datsun Competition Manual
Dodgeman
Posted: 2004/7/22 11:58  Updated: 2004/7/22 11:58
Factory data as requested.
If anyone wants a bigger size, better quality copy of this, just e-mail me & ask.
benny
Posted: 2004/7/23 3:45  Updated: 2004/7/23 3:45
Quick question.........how would i weigh each end [big and small] seperately? As the doc suggests to adjust the weight for each; seperately. Or is the doc referring to match the weights for the bearing caps and little end / rod beam.
cheers
Benny
A14force
Posted: 2004/7/23 6:00  Updated: 2004/7/23 6:00
You have to sit each end on a pin to suport it while you weigh the other end.
