Main : Mechanical : Drive Train h190 diff
[<   Previous  700  701  702  703  704  705  706  Next   >]
h190 diff
h190 diffPopular
Submitterca18det_manMore Photos from ca18det_man   Last Update2004/8/6 13:20    Tell a friendTell a friend
Hits3591  Comments3    0.00 (0 votes)0.00 (0 votes)
Finally all rebuilt and in.
feral
Posted: 2004/8/6 14:08  Updated: 2004/8/6 14:08
 Re: h190 diff
Andrew is it an LSD, a spool or welded????
The back end looks good.
ca18det_man
Posted: 2004/8/6 14:32  Updated: 2004/8/6 14:32
 Re: h190 diff
Errol Its welded for the time being. Im saving for the LSD. I just want to get it going as its been nearly 2 years
Its getting closer I will be ready for bathurst in december. It wont be pretty (painted) but hopefully should have the good gear in ready for sorting.
Ps: Can you keep an eye out for a second hand 720 or early navara LSD I need this type to keep the axles they way they are. I have sourced New from USA $490 US Hoepfully will have a freind over there later in the year to save freigth and import
thanks Andrew
D
Posted: 2004/8/6 23:21  Updated: 2004/8/6 23:21
From: under the Firmament LOL no twiglight effect BS
 Re: h190 diff
Andrew when you get the lsd centre in get rid of those rusty bolts on the diff housing itll make go faster nice work looks ver clean.
What did you use to clean the housing? I found that oven cleaner works a treat but stains alloy grey
