Main : Mechanical : Drive Train H150 diff with spacer for H145 housing
[<   Previous  697  698  699  700  701  702  703  Next   >]
H150 diff with spacer for H145 housingPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2004/9/8 7:58    Tell a friendTell a friend
Hits4042  Comments1    0.00 (0 votes)0.00 (0 votes)
There is some controversy as to whether a spacer is needed ...
Posted: 2006/3/7 4:14  Updated: 2006/3/7 4:14
 Re: H150 diff with spacer for H145 housing
Here's the Pitroad page: B110用H150デフスペーサー
The page says:Quote:
With the H145 diff of B110 standard housing, installing this spacer makes it possible to install an
H150 diff., H150 diff. + H150 L. S. D.
(Use the propeller shaft from B310)
Magic product
Thinking about this, the H150 is 5 mm larger diameter, so you'd need to space it out 2.5 mm from the center line of the housing. This checks with the 1975 B210 housing, which indeed has the housing face 2mm farther away from centerline compared to the 1974 housing of H145 (source: Nissan intro doc, 1975 B210).
