Main : Misc GX dual bolt pattern
[<   Previous  6044  6045  6046  6047  6048  6049  6050  Next   >]
GX dual bolt patternPopular
SubmitterDodgemanMore Photos from Dodgeman   Last Update2004/8/7 13:06    Tell a friendTell a friend
Hits4006  Comments4    0.00 (0 votes)0.00 (0 votes)
The GX cylinder head comes with both of the manifold stud patterns.
Dodgeman
Posted: 2004/8/8 9:08  Updated: 2004/8/8 9:08
 Re: GX dual bolt pattern
Ddgonzal
I think i might have it backwards. I know that the A14/15 heads have three of these coolant holes, but i thought the single one was at the rear. It looks like i got it arse about.
That center hole is normally covered by the manifold & the gasket.
The GX has four of these holes. Is that the full drilled size of that coolant hole, or is it partly blocked?
Whats the story with the rest of that A12a engine. Is it a junker, or will it be rebuilt? I think you know what i need from it.
Dodgeman
Posted: 2004/8/7 13:13  Updated: 2004/8/7 13:13
The factory race option inlet manifold mounted two solex carbs, much like Webbers, & obviously the manifold had the oval ports, but was drilled with the earlier, center stud, manifold stud pattern.
I do not know if any other manifold was ever offered with this stud pattern & port configuration.
GX heads came with the extra holes, just in case one wished to fit this manifold.
Do the A14/15 heads have this extra hole?
The GX also had an extra water outlet hole under the rear pair of inlet ports. A14/15's seem to have only 1 at this location.
Cable_Tie
Posted: 2004/8/7 23:33  Updated: 2004/8/7 23:33
I have seen a fair few Oval port heads off A15's with the centre stud thread tapped. I didn't think any oval port manifolds actually bolted up using this though. . .
Posted: 2004/8/8 2:12  Updated: 2004/8/8 2:12
The head I have here (1981 A12A engine) has the tapped center hole, but no stud in it.
ports
Notice too it has both holes at the rear, but they are much smaller than the GX coolant holes. At the front, there is only one coolant hole.
A14force
Posted: 2004/8/8 5:21  Updated: 2004/8/8 5:21
All the oval port heads I have seen have had this hole.
