Main : Members the donk
[<   Previous  1205  1206  1207  1208  1209  1210  1211  Next   >]
the donk
the donkPopular
Submitterrb20More Photos from rb20   Last Update2004/9/26 9:25    Tell a friendTell a friend
Hits2559  Comments5    0.00 (0 votes)0.00 (0 votes)
sweet
rb20
Posted: 2005/12/18 0:32  Updated: 2005/12/18 0:32
 Re: the donk
can this brake booster be to big as it does not seem to be working i dont think it leaking as the motor does not run rough when i put my foot on the brake i am not sure what this booster is off of but my brakes feel yhard as a rock will i need a smaller booster?????????
tens_and_twenties
Posted: 2005/12/18 0:47  Updated: 2005/12/18 0:47
 Re: the donk
Do you have the large vacuum hose from the booster to the intake manifold connected? Don't see it there...
Dats-hot
Posted: 2005/12/18 1:10  Updated: 2005/12/18 1:10
 Re: the donk
Tens and Twenties is right. The 'boost' for the brake booster is provided by manifold vacuum from the running engine via a hose and a one way valve.
If there is a hose there, it's well hidden.
I don't remember that the original 1200 manifold had provision for the booster's vacuum fitting, so it might be necessary to find an inlet manifold from a late 120Y as these had boosted brakes and the manifold should have provision for the fitting.
tens_and_twenties
Posted: 2005/12/18 5:21  Updated: 2005/12/18 5:21
 Re: the donk
Also a good place to get the check valve from too.
rb20
Posted: 2005/12/19 8:40  Updated: 2005/12/19 8:40
 Re: the donk
this picture was taken long before i got the car on the road it has the vacume line and also an a14 motor now so that is not the problem
L18_B110
Posted: 2005/12/19 13:12  Updated: 2005/12/19 13:12
 Re: the donk
if its got the vacuum line connected and the one-way valve is correctly oriented, then its got to be the booster. Looks to me like a 200B unit, but that's just a guess. Go and compare it to some in a wrecking yard.
