Main : Misc : Tech Section 120Y & 1200 swaybars
[<   Previous  430  431  432  433  434  435  436  Next   >]
120Y & 1200 swaybarsPopular
SubmitterAutokatMore Photos from Autokat   Last Update2004/9/30 4:20    Tell a friendTell a friend
Hits5217  Comments7    0.00 (0 votes)0.00 (0 votes)
Just posting this so everyone can see the differences between the two.
L18_B110
Posted: 2004/9/30 6:21  Updated: 2004/9/30 6:21
 Re: 120Y & 1200 swaybars
yeah, the 120Y bar is a bit wider, but it fits perfect if you're using the longer Stanza control arms.
snowy
Posted: 2004/9/30 6:56  Updated: 2004/9/30 6:56
120Y bar is quite a bit thicker in diameter too.
Posted: 2004/9/30 7:00  Updated: 2004/9/30 7:00
Swap info is described in Suspension article.
L18_B110
Posted: 2004/9/30 7:44  Updated: 2004/9/30 7:44
I guess I assumed everyone knew that.
Its 3mm larger diameter (20mm) and represents a 63% increase in rate over the original bar (17mm).
2332owner
Posted: 2004/9/30 15:01  Updated: 2004/9/30 15:01
This is a little OT but that new avatar is sexy L18_B110.
ronald_loulan
Posted: 2010/7/19 14:58  Updated: 2010/7/19 14:58
Need hepl here...
Is the ARB a PNP for 1200?
Coz it looks wider...
Tq...
Posted: 2010/7/19 23:31  Updated: 2010/7/19 23:31
What did you say?
The B210 sway bar is not wider, it's only because of the photograph the piece farthest from the camera looks smaller. See Sway bar swap for details.
