Main : Misc brake booster
[<   Previous  5895  5896  5897  5898  5899  5900  5901  Next   >]
brake booster
brake boosterPopular
SubmitterNIS15LMore Photos from NIS15L   Last Update2004/9/30 11:43    Tell a friendTell a friend
Hits6272  Comments10    0.00 (0 votes)0.00 (0 votes)
under dash
Dodgeman
Posted: 2004/12/14 14:44  Updated: 2004/12/14 14:44
 Re: brake booster
These boosters are really good & were very popular in the years when FB Holdens still had warranty, [Early 60's] but were designed for a single circuit operation. If you want to add boost to both ends of a dual circuit brake system, then you need two boosters.
The round thing protruding downwards is a filter [with valving]
This strains the rocks out of the air that passes into, & out of, the diaphram chamber when it "breathes" during brake application. The sound of it breathing under the dash of a street car may cause some passengers to wory what kind of pet you have lurking under there, but in a racer, you will never hear it above the cheering of the crowd.
The pipe coming to the top rear of the cylinder supplies hydraulic pressure from the master cylinder. The fitting at the end of the cylinder that points upward is the bleeder nipple. The unit is best installed with the cylinder pointing slightly upward to get a good bleed. The pipe at the end of the cylinder goes to the brakes. The rubber hose supplies vacuum from the manifold, or from a vacuum storage tank. This one looks to be both well engineered, & properly installed
They work a treat but were superceded by the type that mounts the master cylinder as this design needs only one booster to work a dual circuit brake system.
PS
If you find one in a junk car, don't throw it out, take it to a swap meet. They are still popular & some places specialise in reconditioning them.
ang94541
Posted: 2004/12/14 19:31  Updated: 2004/12/14 19:31
 Re: brake booster
ah ha
single circuit, line-in, line-out
I got it.
EDIT: Nope, I got lost again.
http://datsun1200.com/modules/myalbum/photo.php?lid=5339
In this engine pic there appears to be a dual circuit master. Is only one circuit being boosted?
UTE18L
Posted: 2004/12/14 6:40  Updated: 2004/12/14 6:40
 Re: brake booster
What year is your ute NIS15L, its rust free
NIS15L
Posted: 2004/12/14 6:46  Updated: 2004/12/14 6:46
 Re: brake booster
Its an 84 model mate its does have couple spot of rust 1 under the acellarator pedal 1 on the a pillar and one under the tailgate where those black stops used to be, none bigger than a 50c coin tho.
rb20
Posted: 2004/12/14 8:10  Updated: 2004/12/14 8:10
 Re: brake booster
1967 ford XR fairmonts have these boosters from the factory i just through one out a few mounths ago
2332owner
Posted: 2004/12/14 10:24  Updated: 2004/12/14 10:24
 Re: brake booster
I still don't get it... how does the mechanical action of the brake pedal get all the way over there... it may be obvious but I just don't get it.
converted
Posted: 2004/12/14 10:57  Updated: 2004/12/14 10:57
 Re: brake booster
must run a small cylinder off the brake pedal the transfers hydraulically to the cylinder on the booster...I guess.....
ang94541
Posted: 2004/10/1 8:32  Updated: 2004/10/1 8:32
 Re: brake booster
I've never seen this before.
Can you please briefly explain how your brakes work. And what happens if your engine shuts off?
dazzasute
Posted: 2004/10/1 8:36  Updated: 2004/10/1 8:36
 Re: brake booster
and how street legal it is ???
Autokat
Posted: 2004/10/1 9:19  Updated: 2004/10/1 9:19
 Re: brake booster
This is what they do in hotrods if you want to find out the legalities and how it's done have a look on some rodder sites.
NIS15L
Posted: 2004/10/3 3:04  Updated: 2004/10/3 3:04
 Re: brake booster
Its perfectly legal and will be fully engineered.
it works the same as any brake booster its just remotely mounted.
