Main : Misc clutch master
[<   Previous  5889  5890  5891  5892  5893  5894  5895  Next   >]
clutch master
clutch masterPopular
SubmitterNIS15LMore Photos from NIS15L   Last Update2004/9/30 11:48    Tell a friendTell a friend
Hits3828  Comments3    0.00 (0 votes)0.00 (0 votes)
again under dash
Wattage
Posted: 2006/6/30 3:56  Updated: 2006/6/30 3:56
 Re: clutch master
Guys,
Does anyone knwow what this master cylinder is off? I have asked Luke, but he is unsure. Apparently it is a motorbike item. I just like the way it's neat and small, and has a tapped hole for a brass fitting.
Unfortunately, I don't have any room in the engine bay for a master cylinder.
Thanks.
datsik
Posted: 2006/11/15 6:25  Updated: 2006/11/15 6:25
 Re: clutch master
that is NOT of a bike...looks like a standard19mm cylinder with a tapped end to fit the brass fitting.
Bugger....looks a whole heap neater than my effort.
dattoman_1000
Posted: 2006/11/15 11:16  Updated: 2006/11/15 11:16
 Re: clutch master
Its actually a Girling "claypipe" master
You can get them in 5/8 and 3/4 easily and sometimes .7" if you look hard enough
Usually a 5/8 for clutch applications
Worth about $70
Threads are 3/8 unf for pipe outlet and 7/16 unc for fluid in
