Main : Mechanical : Engine L20B in 720
[<   Previous  2594  2595  2596  2597  2598  2599  2600  Next   >]
L20B in 720
L20B in 720Popular
SubmitterTyrieMore Photos from Tyrie   Last Update2004/11/2 8:50    Tell a friendTell a friend
Hits3908  Comments3    0.00 (0 votes)0.00 (0 votes)
L20B in my ute, twin SU's, electronic dizzy, cam, high comp pistons etc Needs a bit of work but it runs well. Rebuilt 30,000k ago.
Tyrie
Posted: 2004/11/7 10:27  Updated: 2004/11/7 10:27
 Re: L20B in 720
so ya reckon it'd pass over the pits with hoses venting it under the car?
Or if i put them into a 'T' piece and ran it into the charcoal cannister?
The cannister has a tube for A/C, but I dont have A/C, so I was thinking of just plumbing the carb hoses into there
Dodgeman
Posted: 2004/11/7 13:22  Updated: 2004/11/7 13:22
 Re: L20B in 720
If you got a couple of real air cleaners, you know, dome aftermarket type [Ramflow?] & ran the tubes to a fitting in the base plates, you should have no real problems in my view.
I guess that you could even run the two hoses to a "T" piece & then to one air cleaner only. That way any hydrocarbons [fumes] will be sucked into the engine & burned. That should do the trick.
I don't know for sure, but i think the A/C on the canister is for Air Cleaner, not air conditioner. The canister needs clean filtered air to do it's job properly.
Tyrie
Posted: 2004/11/7 23:03  Updated: 2004/11/7 23:03
 Re: L20B in 720
Thanks Dodgeman
Tyrie
Posted: 2004/11/6 10:17  Updated: 2004/11/6 10:17
 Re: L20B in 720
OK, on ech carb there are two pots, one below where the fuel goes in and one above (this has flat top)
On the top of the lower ones there is a tube sticking out for a hose to go over. Where should this hose go?
Dodgeman
Posted: 2004/11/6 10:45  Updated: 2004/11/6 10:45
 Re: L20B in 720
On the earlier round top carbs on my GX engine, these had a pipe that ran down the side of the block to a little bit below the sump gasket level. They are to vent the bowls & provide an overflow for overfilled bowls.
Yours would have been connected to the clean air side of the original SSS air cleaner housing.
Your carbs look like they are not SU's, they are even better, they look to be Hitachi's from something like a 180B SSS [610 SSS] That's how the hoses are shown in my 180B manual.
If thats a factory inlet maniflod, then see if you can find an air filter assembly from a 180B SSS. I guarantee that you will not lose performance compared to the rock seives that you have now.
On 910's [Bluebirds] these hoses were connected to a solenoid system that, when the ignition was on, vented them to the air filter, but when the ignition was off, they were vented direct to manifold vacuum. This placed an equal pressure both above & below the fuel in the bowl. Since fuel only flows as a result of pressure diferential, & this pressure suddenly becomes equal, then the fuel does not flow, & any running-on problems dissapear as there is no fuel being sucked in to burn.
This has the same effect as the idle cut off solenoid in the downdraught carbs.
Very clever those Datsun engineers
