Main : Misc : Forum thermo fan
[<   Previous  523  524  525  526  527  528  529  Next   >]
thermo fan
thermo fanPopular
SubmitterboofheadMore Photos from boofhead   Last Update2005/1/14 8:56    Tell a friendTell a friend
Hits2847  Comments4    0.00 (0 votes)0.00 (0 votes)
n31 pulsar(i think) thermo fan.
cheap to buy and works FANtastic!!!!
evilsim
Posted: 2005/1/15 0:15  Updated: 2005/1/15 0:15
 Re: thermo fan
when i was researching which fan and what to use etc i read that a fan in a 'push' setup (infront of the radiator at front of car) is 15% or so LESS efficient than having it as a 'pull' setup. although i cant see the picture anymore as it looks like a blackdot, thought id just say. i couldnt fit mine as a pull but it works a treat as a pushing fan. 12" fan kit from repco and davies craig controller, on an old gemini radiator w/ overflow.
with the repco/aftermarket fans, you can switch the direction of the blade so u can use it as a push or pull.
4NIK8
Posted: 2005/1/15 8:02  Updated: 2005/1/15 8:02
 Re: thermo fan
boofhead
Posted: 2005/1/14 9:01  Updated: 2005/1/14 9:01
 Re: thermo fan
cost me $25.00 from a wrecker, $55.00 for a davies craig thermal switch and a few hours installation. Fits fantastic behind the grille and wth the original shroud completely covers the radiator
just the thing for these hot summer days cruising the coast
feral
Posted: 2005/1/14 10:30  Updated: 2005/1/14 10:30
 Re: thermo fan
Damn fine value and will work a treat!
It would be from an N13.
L18_B110
Posted: 2005/1/14 10:41  Updated: 2005/1/14 10:41
 Re: thermo fan
shroud??? I wouldn't run a shroud in front of the rad! Is the N13 fan designed to run in that location?
boofhead
Posted: 2005/1/14 22:34  Updated: 2005/1/14 22:34
 Re: thermo fan
shroud may be a bit of overkill ...more the frame i suppose. the fan originally sits behind the rad in the pulsar but i've turned the blades around on the fan motor so now it blows instead of sucks
Dodgeman
Posted: 2005/1/14 23:16  Updated: 2005/1/14 23:16
 Re: thermo fan
Turning the fan around will not reverse its direction of airflow, it just reduces the level of fan efficiency because now you have the back of the blade doing the work.
With the engine off, see if you can make the fan run & hold a small piece of paper near the running fan. Which way does it blow?
