Main : Members : benny stanza struts, Tokico inserts, Cusco Camber plates
[<   Previous  49  50  51  52  53  54  55  Next   >]
stanza struts, Tokico inserts, Cusco Camber platesPopular
SubmitterbennyMore Photos from benny   Last Update2005/1/27 22:48    Tell a friendTell a friend
Hits3319  Comments1    0.00 (0 votes)0.00 (0 votes)
A pair of struts I put together last weekend.
Stanza strut bodies, stub axles has been bent to neg 3 degrees.
shocks-Tokico inserts
Cusco Camber plates
120yrally
Posted: 2005/1/31 0:19  Updated: 2005/1/31 0:19
Not too shy to talk
 Re: stanza struts, Tokico inserts, Cusco Camber plates
where did you get the inserts and camber plates from? I run stanza struts in the 120y and it so hard to find good strut inserts!
and may i ask how much both of these are?
LAGWAGON
Posted: 2005/1/31 2:05  Updated: 2005/1/31 2:05
yeah they look sweet! i have been looking for reasonably priced camber plates for ages, where did you get those bad boys from? and what did they cost you if you don't mind me asking?
benny
Posted: 2005/1/31 4:17  Updated: 2005/1/31 4:17
Unfortunately, camber plates are not reasonably priced anywhere. These Cusco ones are $660 Au new and I got them $550 second hand. Tokico Inserts are very well priced Around $250 / pair from memory, I dont think they are being imported into Australia at the moment. modified stub axle angle, $160 from memory.
Im planning to put them in a motokarna car I want to build up. This could be in some time, if at all. Its quite a bit of work maintaining just 1 racecar.
I might be tempted to sell them for the right offer.
Benny
boofhead
Posted: 2005/1/31 6:06  Updated: 2005/1/31 6:06
check here for camber adjustible top plates at what i thinks not too bad a $$$
http://www.datrats.com.au/SUSPENSION.html
