Main : Members : 2332owner Fender flare
[<   Previous  18  19  20  21  22  23  24  Next   >]
Fender flare
Fender flarePopular
Submitter2332ownerMore Photos from 2332owner   Last Update2005/3/7 13:53    Tell a friendTell a friend
Hits2738  Comments4    0.00 (0 votes)0.00 (0 votes)
Rear view
4NIK8
Posted: 2005/3/8 0:01  Updated: 2005/3/8 0:01
 Re: Fender flare
looks great, i plan to do this to my ute one day.
did you do it yourself? details please :p
datman55
Posted: 2005/3/8 0:35  Updated: 2005/3/8 0:35
 Re: Fender flare
Looks great....top job
2332owner
Posted: 2005/3/8 2:13  Updated: 2005/3/8 2:13
 Re: Fender flare
No I'm more of an apprentice... I'm being taught how to do it on my own truck so that's cool. First the spot weld need to be cut then the outer sheet needs to be stretched quite a bit. We welded about 2 cm of extra metal to the end of the existing outer sheet then got it where we wanted it, re welded the inner and outer sheets together then formed the lip again and cut off the little bit of excess we had. A little body filler and primer and there it is. Fronts should be a lot easier as there's only one layer.
A14force
Posted: 2005/3/8 7:58  Updated: 2005/3/8 7:58
 Re: Fender flare
looks very tastefull.
