Main : Misc After
[<   Previous  5526  5527  5528  5529  5530  5531  5532  Next   >]
After
AfterPopular
SubmitternzdattomanMore Photos from nzdattoman   Last Update2005/3/30 10:41    Tell a friendTell a friend
Hits2404  Comments5    0.00 (0 votes)0.00 (0 votes)
Disc Brake conversion
nzdattoman
Posted: 2005/4/3 7:01  Updated: 2005/4/3 7:01
 Re: After
they are standard 1200 front discs , yes they bolt straight in. I believe sunny struts are taller ? inch and a half maybe ? but they will bolt straight in provided you drill out the holes in the top of the strut tower as studs are larger in diameter. As for changing the wheel cylinders in the rear brakes i did'nt know you had to with this conversion, please explain more.
ps.sunny struts would make car ride higher if lowered springs were not fitted eg. Tractor
Dodgeman
Posted: 2005/3/31 11:29  Updated: 2005/3/31 11:29
 Re: After
Did you put the correct rear wheel cylinders in too? This is important, or else it's an unsafe half job.
kegs
Posted: 2005/3/31 7:41  Updated: 2005/3/31 7:41
 Re: After
are these sunny struts?
wat exactly do u need from the sunny to bolt em all up some people say they go straight in, some dont i wanna know for sure off someone thats done it......
TnPshow
Posted: 2005/3/31 12:56  Updated: 2005/3/31 12:56
 Re: After
They definately do look like sunny disks. The sunny disk is about 30mm bigger in diameter than the 1200...
TC
120fly
Posted: 2005/3/31 13:09  Updated: 2005/3/31 13:09
 Re: After
The disk look to be 120 y .Did they bolt straigt in ? AS the 120y ones will there are some modifications to be done ...maybe someone can explain id like to learn abit more myself ive read some of the tech sections they helped .Cheers
boofhead
Posted: 2005/4/3 9:05  Updated: 2005/4/3 9:05
 Re: After
120fly - 1600 strut assemb and brakes, including hoses, will bolt into a 120y, you need lowerd (or cut off 2 coils) springs to get it to ride level. you can go 1600 outer rod ends or if you can find 1968/69 1600 steering arms, these have smaller holes.
this helps the stopping of the car imensly, and the 1600 struts are usually pretty cheap
