Main : Members : 1200rallycar A15ETT progress picture (14/04/05)
[<   Previous  21  22  23  24  25  26  27  Next   >]
A15ETT progress picture (14/04/05)Popular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2005/4/14 9:07    Tell a friendTell a friend
Hits3682  Comments5    0.00 (0 votes)0.00 (0 votes)
i dont think you'll ever see so much hanging off an a15
1200rallycar
Posted: 2005/4/14 9:17  Updated: 2005/4/14 9:17
 Re: A15ETT progress picture (14/04/05)
- a15, stock except for mild street cam (not designed for boost)
- factory injection manifold
- JE camira computer and loom (delco 808)
- all JE sensors including throttle body and coil
- factory a-series dizzy using camira module
- a-series injectors with added resistors to change resistance
- 2x diahatsu diesel 1000cc turbos, running independently on 2 cylinders each
- aiming for 8-10psi boost
- 1.6l surge tank ("lagwagon") with nissan l28 pump as lift pump and high psi VL pump
- added fuel line for inlet 5/16, used stock line as return
- ea falcon alternator
- gemini radiator, 10" craig davies thermo
- intercooler (2 silvia ones welded together), blow off valve (stock silvia)
- escort throttle cable (shouldn't admit that )
who_your_datty_1200
Posted: 2005/4/14 12:25  Updated: 2005/4/14 12:25
I think that we'll see a weeee bit more hanging off that A15 once you put the other two turbos on there
Nice work to get it up and running. I'll be putting in the fuel line for mine on monday(I hope) and then I can finally start to get mine going!!
ANGE
Posted: 2005/4/14 14:09  Updated: 2005/4/14 14:09
nice work mate...
a fuel injected twin turbo charged datsun motor....
you wouldnt read about it!
what improvements are you expecting from the beast over the tturbo carby set up...?
1200rallycar
Posted: 2005/4/15 2:51  Updated: 2005/4/15 2:51
well considering the carby i put on the old setup ws never tunned (came straight off my bros 1600 esort)
and the nature of injection plus the fact its getting a proper tune up, there should be HEAPS more power through the rev range and 10 times the drivability, in all should be heaps quicker, but i wouldnt expect peak power to be much higher
D
Posted: 2005/4/16 5:05  Updated: 2005/4/16 5:05
From: under the Firmament LOL no twiglight effect BS
Well done mike youve just proved that the craziest things are possible even to the ones who thought it impossible.
I supposed a little madness helps
