[< Previous 22 23 24 25 26 27 28 Next >]
07. Exhaust valves
SLAM1024 2005/4/18 3:24 Tell a friend
2175 2 0.00 (0 votes)
| I was wondering about these when I saw them, I thought that it had probably been ran lean/hot, sent the picture to my dad to confirm it, told me to find out how well the valve seats by pouring gas down there and see how fast it leaks through, I'll try that but gas is so expensive to waste nowadays :P |
| Poster |
Thread |
| SLAM1024 |
Posted: 2005/4/18 3:26 Updated: 2005/4/18 3:26 |
Home away from home   Joined: 2002/8/8 From: Lethbridge, AB, Canada Posts: 251 |
 Re: 07. Exhaust valves This picture doesnt do it justice really, if you were in my garage right now you could see how bad they look
| Poster |
Thread |
| ddgonzal |
Posted: 2006/4/24 6:29 Updated: 2006/4/24 6:29 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31854 |
 Re: 07. Exhaust valves The white color might indicate hot/lean. The buildup on there is probably a lot of gasoline additive. But maybe oil ran down from above and burnt on the stem.
To save money, just use water. It should hold water overnight. However, with that buildup I would disassemble the valves, clean the with a wire brush on a drill, and then hand-lap them back in. If it doesn't hold water, they should be ground on a machine.
Also check the valve side-to-side play. If there is any play have new guides put in. I didn't have much success with kurnling the guides.
I recommend the umbrella style of oil seal (ford-style) that ride on the valve like an upside down thimble. The positive seal type that fits over the guide seem to pass to much oil except when the guides are brand new.
