Main : Misc : Forum front of googs ute
[<   Previous  478  479  480  481  482  483  484  Next   >]
front of googs ute
front of googs utePopular
SubmitterDatsun4GoogsMore Photos from Datsun4Googs   Last Update2005/4/29 14:07    Tell a friendTell a friend
Hits3445  Comments21    0.00 (0 votes)0.00 (0 votes)
i like big intercoolers maybe its overkill?
ZigZag
Posted: 2011/4/22 9:41  Updated: 2011/4/22 9:41
 Re: front of googs ute
soooo not cool
dattodevil
Posted: 2005/4/30 3:59  Updated: 2005/4/30 3:59
Is that a Rabbit?
flyby
Posted: 2005/4/30 9:52  Updated: 2005/4/30 9:52
You would be lucky to be using 50% of that cooler, the rest is there to help cause lag
Datsun4Googs
Posted: 2005/4/30 13:53  Updated: 2005/4/30 13:53
Not too shy to talk
mmm aint no lag in there mate!
flyby
Posted: 2005/5/1 12:17  Updated: 2005/5/1 12:17
well ok then, did your lag-o-metre tell you that?
place a boost gauge on each side of that cooler, you would find a massive drop! its simple science
woodydat
Posted: 2005/5/1 12:27  Updated: 2005/5/1 12:27
yeh im with flyby, that intercooler is way to big, u would only be using the top half of that cooler, coz the boosted air will flow throo the top half and wont have enough pressure to run throo the bottom half.
dattodude
Posted: 2005/5/1 12:34  Updated: 2005/5/1 12:34
Ok so if there's no lag in there, what the best 1/4 mile? This personal slanging match needs to be matched up with fact.
190kW isn't hanging around, should be good for 11s. What's your Ute weigh? We had a discussion recently and found sub 900kgs was about normal.
Sounds like you've been running this setup for a while, so I'm keeping an open mind.
Datsun4Googs
Posted: 2005/5/1 12:52  Updated: 2005/5/1 12:52
Not too shy to talk
this car has been running in the 11s for along time it weighs in at under 900kgs 860 last time. you dont get much pressure drop as it is tube and fin! bar and plate maybe! this setup works fine had no probs so far maybe its one of them miths that bigger isnt better! i will post a time card on this ute.
flyby
Posted: 2005/5/1 12:59  Updated: 2005/5/1 12:59
double post
flyby
if all your doing is straight line then you probably wouldn't notice the lag.
street and circuit driving would be dramatically improved with a better design.
Regular 11 quarters? nice, what the details on the engine hardware?
flyby
Posted: 2005/5/1 13:03  Updated: 2005/5/1 13:03
the type of core is irrelevant in this case its size and design thats no good.
Datsun4Googs
Posted: 2005/5/1 13:18  Updated: 2005/5/1 13:18
Not too shy to talk
this ute is only made for straight line as iam not into street or circuit! we are talking to different moter sports! the ca has heavily ported head one peice tapperd valves, springs cams cam wheels ge forged pistons shotpeened rods all ballenced 600cc injectors and a xf throttle body gt 28 turbo. and it is a provin fact that you will get more pressure drop with bar an plate regairdless of its size and design
phunkdoktaspok
Posted: 2005/5/1 13:24  Updated: 2005/5/1 13:24
lol you talkin out your ass now.
I got not disrespect for you or your car.
But something that was designed to flow better with less restriction ( Bar and Plate ) compared to extruded tube ( Tube and Fin )
You crack me up more than Dattodevil.
Demojob
Posted: 2005/5/1 13:35  Updated: 2005/5/1 13:35
I like the power it produces, good work.... How much did all those mods cost but?? (Just to the engine)....
Althought I'm not a big fan of the intercooler but I see you've set it up for drag so then it's needed as every advantage helps especially in intake chage temps.
Cheers
Damo
Datsun4Googs
Posted: 2005/5/1 13:45  Updated: 2005/5/1 13:45
Not too shy to talk
thanks for your input guys mybe we will all meet at the drags some time! i still like my intercooler
phunkdoktaspok
Posted: 2005/5/1 13:07  Updated: 2005/5/1 13:07
I think you will find Bar and Plate will have less pressure drop and Tube and Fin will have more pressure drop but better Heat dispersion.
I am still cracking up at Dattodevil
ANGE
its obvious that everyone has their own opinion...
i personally would trade any power gains to have my front end back to normal..
but if googs thinks it looks nice and is happy with the way it works then we should respect that..
at the end of the day 190rwkw in a 1200 ute deserves some respect no matter how its achieved
phunkdoktaspok
Posted: 2005/4/30 10:54  Updated: 2005/4/30 10:54
Is that a Rabbit?
BAD310
Posted: 2006/5/6 15:59  Updated: 2006/5/6 15:59
Is that a Rabbit?
I don't understand where the rabbit comes into it?
Can someone please explain.
Cheers
phunkdoktaspok
Posted: 2006/5/6 16:13  Updated: 2006/5/6 16:13
Think bugs bunny when you look at the pic
BAD310
Posted: 2006/5/6 16:16  Updated: 2006/5/6 16:16
Ha Ha Ha I like it.
Thanks Phunk.
