Main : Members : benny A Series head porting.
[<   Previous  41  42  43  44  45  46  47  Next   >]
A Series head porting.Popular
SubmitterbennyMore Photos from benny   Last Update2005/5/6 7:14    Tell a friendTell a friend
Hits3492  Comments5    0.00 (0 votes)0.00 (0 votes)
Here is a quick pic of an A Series head that I ported myself.  It took about 8 hours to do.  Based on Std valves and the valve stem guides have shortened.  I guess proof that it works will be when I run the car on the track next weekend.
Benny
Posted: 2014/1/12 23:56  Updated: 2014/1/12 23:56
 Re: A Series head porting.
How did it tun on the track?
D
Posted: 2014/1/16 15:08  Updated: 2014/1/16 15:08
From: under the Firmament LOL no twiglight effect BS
Yeah Benny same here
benny
Posted: 2014/1/19 22:53  Updated: 2014/1/19 22:53
It went OK, It's still on the old engine sitting in the shed. Upgraded last year to the e85 burning A-series. The cam was more of a rally grind, (74 degrees FIA], and ran well up to ~7,400rpm, Pistons are 76mm oem items. Its an open chamber type head and from memory I took quite a bit off the face to increase compression a little.
I may use it again, maybe in efi turbo application one day... I think it would be a good starting point for that type of build.
cheers
killer1200
Posted: 2005/5/6 19:06  Updated: 2005/5/6 19:06
Tell us if it flows well in a race situation.
sunny
Posted: 2005/5/6 12:54  Updated: 2005/5/6 12:54
did you take the short turn radius down to drop the floor of the port also ,and de- shroud the guides, as I found this had allowed a bigger increase in flow than work done on the roof of the port
looks like you have a nice even finish ,hopefully all that time to do a good job pays off !
