Main : Misc 60 series 4 speed Vs 3N71B auto
[<   Previous  5391  5392  5393  5394  5395  5396  5397  Next   >]
60 series 4 speed Vs 3N71B autoPopular
SubmitterMawler1More Photos from Mawler1   Last Update2005/5/7 15:23    Tell a friendTell a friend
Hits4678  Comments9    0.00 (0 votes)0.00 (0 votes)
anyone that is considering doing the swap I HIGHLY reccomend it!
it makes gutless cars fun!
juniorjay
Posted: 2009/5/30 3:31  Updated: 2009/5/30 3:31
 Re: 60 series 4 speed Vs 3N71B auto
hi mate
this pictures probably heeps old
but was just after confirmation
the 60 series gearboxs bolt up to the automatic tunnel using the automatic crossmember (maybe reversed)
correct?
any replies much appreciated
Posted: 2009/5/30 5:47  Updated: 2009/5/30 5:49
So they say ...
You do need a manual driveshaft. The transmission if different length from automatic.
Dodgeman
Posted: 2007/3/17 12:40  Updated: 2007/3/17 12:40
Of course, you could have switched to the 4N71B trans & had the converter modified for a higher stall.
Better launch, smooooth cruisin & overdrive to boot.
Cable_Tie
Posted: 2005/5/10 7:52  Updated: 2005/5/10 7:52
Tailshafts, same length? Same Splines?
Mawler1
Posted: 2005/5/10 8:58  Updated: 2005/5/10 8:58
they are the same length: however the yokes are different: the pic gives a clue. the auto tailshaft is shrouded/hooded where as the manual gearbox is shrouded/hooded, also the auto yoke is larger diamater and is longer!
Meat_rack
Posted: 2005/5/10 9:54  Updated: 2005/5/10 9:54
Thats not a trimatic is it?
Nooooo!
Mawler1
Posted: 2005/5/10 15:27  Updated: 2005/5/10 15:27
no, It is a Jatco 3N71B - it's not going back in either! I like the F4W60A (I think it'an F4W60A) much better
blofly
Posted: 2007/3/17 5:34  Updated: 2007/3/17 5:34
hmmm So to do the swap Did you need the box, pedal assembly, tail shaft, clutch cable, flywheel, shifter, clutch assembly and crossmember from a manual 1200/120Y?
any thing else I have forgotton? may be attmpting this soon just worried how long the diff and box would last behind a worked A15 and to swap to a H165 diff and strong 5 speed would be too expensive
Freak
Posted: 2007/3/17 5:44  Updated: 2007/3/17 5:44
My 20000km h145 lasted two days behind a worked a14 and a manual comapared to the stock A12 auto. It wasn't as hard driving as some would assume. Must have just hit it at the right time to blow it to pieces.
