Main : Members : woodydat woodydats ute update
[<   Previous  1  2  3  4  5  6  7  Next   >]
woodydats ute updatePopular
SubmitterwoodydatMore Photos from woodydat   Last Update2005/5/31 14:27    Tell a friendTell a friend
Hits3255  Comments6    0.00 (0 votes)0.00 (0 votes)
here she is, bare shell now, sitting on 44 gallon drums, ready for the the rust repair to be done on the underside, and all mounts fixed and suspension all shmick.
sorry bout the photo, took it off my phone.
Dodgeman
Posted: 2005/6/1 16:27  Updated: 2005/6/1 16:27
 Re: woodydats ute update
The 180B SSS was sold in Australia with three diferent induction systems i believe.
Twin Hitachi round tops
Twin Hitachi square tops
Single Hitachi downdraught.
Just which head went with which induction is beyond me.
I think that you're right, it's the heads casting number that makes all the diference, but i seem to remember reading somewhere that the ports on the L20b head were as good as any, so maybee it's in the combustion chamber that the power lies.
Ahhh what do i know when it comes to L series, i guess that Feral would be one of the blokes who would know for sure what the hot setup was. The only thing that i knew was that there was only one L20b head used in Australian models, SSS or otherwise. Just compare the valve sizes of the SSS head against the L20b's head.
If your guards & bonnet are shot, then have a look at the new Malasian made front sheetmetal parts that are available from Wetheril Park Panels. They may possibly prove to be a proposition, & if you like the coupe grille, as used on utes in '74 & '75, then they have new ones of these too.
Guards $65 [each]
Bonnet $110
Grille $40
woodydat
Posted: 2005/6/2 8:50  Updated: 2005/6/2 8:50
thanks dodge man, but i got new front quaters, and new door skins, the boonet is fine. and i want a sedan grille which im getting off a mate.
infact i want a rustless 1200 ute.. but i dont think it will ever happy :(
ive found so much rust in the last couple of days its near on bringin me to tears thinking about how much work it needs.
but i know once its all done it will be worth it.
boofhead
Posted: 2005/6/2 9:15  Updated: 2005/6/2 9:15
you're in luck today just finished doing it tonight the list goes :
1200 strut tops
2" lowered stanza springs (or the orig 1200 springs to keep similar height)
stanza strut bodies, girlok calipers preferably
stanza brake hoses
stanza steering arms
stanza ball joints
stanza lower control arms and pivot bolts
stanza outer tie rod ends (to go into steering arms)
120y radius/castor rods.
the only bit i needed to modify was the radius rod, lined up and bolted the threaded hole, then had to redrill the other hole to line up with the hole in the controlarm/balljoint.
took about a day to clean up enough room in the garage, get the car in pull out all the existing bits and put in the new bits.
took my slack a$$ about 3 weeks and then some to reco, clean and paint all the bits
hope this helps ........ and everyone else that asks can find it with the seach bar
and this is the thread ........ http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=16197&forum=1#72869
woodydat
Posted: 2005/5/31 14:30  Updated: 2005/5/31 14:30
yeah i know, its takin ####in ages to get to this stage, but u notice the shed thats in? yeah blame dad for taking his sweet ass time in building it! let the MAHEM Begin.!!
Oh yeah, i got a L20b for it too, 40 thou over bore, new pistons ( not forgies :'() balanced crank, shotpeened rods.
i got a whole 200b sittin up the back yard for parts for the L20b.
im doing a swap with a bloke, for a SSS l20b head.
just needs a cam.
I got a single 45mm sidedraught delorto for it too. on a lynx manifold.
should be a little rip snorta once i get it going. i just wana see the look on my mates faces when i take em for a drive, there always givin me #### bout having a ####ty old datsun with rust and no steering wheel or seats. IDIOTS I TELL YOU!,
enough dribble from me, im gunna go wipe my chin
woodydat
Dodgeman
Posted: 2005/5/31 14:53  Updated: 2005/5/31 14:53
Poster: woodydat Date: 2005/6/1 0:30:17
Whats the diference between a 200B SSS head & a regular L20b head? The 200B was the last of the SSS models sold in Australia & used a single carb L20b engine.
According to my 200B & Bluebird parts books, part number 11041 U6083 was the only head used on L20b's in Australia from the 200B untill the last one in the Series 2 Bluebird.
phunkdoktaspok
Posted: 2005/5/31 15:11  Updated: 2005/5/31 15:11
Even sitting on drums, its still faster then their no cars, and cooler than any other.
Hey dont sweat over the ute taking time. It will get there and evolve.
Speaking of Evolve, something tells me you have matured a fair bit since your first posts
Keep it up mate.
Cheers Steve
pro-240c
Posted: 2005/6/1 7:54  Updated: 2005/6/1 7:54
looking good woody.
woodydat
Posted: 2005/6/1 13:39  Updated: 2005/6/1 13:39
hey dodgeman, its either a 200b or 180b sss head, its the A87 head. thats as much as i know, i got some stanza struts coming too. 100 bux with good calipers.
yeah cheers phunk, yeah its just funny, and i found alot more rust tonight, in the engine bay, in that little gutter its pretty ruff, but i'l get ther, dad said the cross member and swing arms are ####ed and bent. but i know were a wrecked 1200 ute is close buy which i can use.
yeh thanks pro-240c
hows urs going,
i lost a post on fitting stanza struts, boofhead wrote up all the things u need to swap them? do you's no whre it is?
cheers. woodydat.
pro-240c
Posted: 2005/6/2 10:12  Updated: 2005/6/2 10:12
yeh thanks pro-240c
hows urs going,
good - twin turbo now.
A87 peanut chambered head is a 180B SSS head from the twin SU motor.
it's the good one, just behind the V91 (200B factory LPG) and the W53 not far behind (L16 SSS) the A87.
