Main : Mechanical : Engine Mitsu 4G92G Mivec
[<   Previous  2473  2474  2475  2476  2477  2478  2479  Next   >]
Mitsu 4G92G Mivec
Mitsu 4G92G MivecPopular
SubmitterGrunterhunterMore Photos from Grunterhunter   Last Update2005/6/13 11:27    Tell a friendTell a friend
Hits3435  Comments1    0.00 (0 votes)0.00 (0 votes)
fat factory extractors!!
Dodgeman
Posted: 2005/6/13 11:41  Updated: 2005/6/13 11:41
 Re: Mitsu 4G92G Mivec
If that's the thermostat housing near the flywheel, then what do you have in mind for radiator placement?
The whole thing also looks a bit tall. Have you run a tape over it?
Grunterhunter
Posted: 2005/6/13 11:57  Updated: 2005/6/13 11:57
Yeah, it is a bit tall, 670mm from sump to oil cap, 600 from crank angle sensor to crank pulley, 315 from the CL on the inlet side and 240 on the exhaust..... would be easier on a LHD.... Would probably need a custom inlet to clear the brake master on a RHD.
You would have to fabricate an outlet from the back of the head and relocate the thermostat using a remote unit from another front driver. It would be a fair bit of work.
