Main : Members : kegs air filter and boost piping
[<   Previous  89  90  91  92  93  94  95  Next   >]
air filter and boost pipingPopular
SubmitterkegsMore Photos from kegs   Last Update2005/7/19 9:51    Tell a friendTell a friend
Hits2533  Comments6    0.00 (0 votes)0.00 (0 votes)
all stainless steel !!!!
Posted: 2005/7/21 7:28  Updated: 2005/7/21 7:28
 Re: air filter and boost piping
Looks like big exhaust tubing. What size are the exhaust?
kegs
Posted: 2005/7/21 9:43  Updated: 2005/7/21 9:43
umm the pipe for the filter is 90mm the piping to the inlet manifold is 50mm and the actual exhaust is 2.5 inch.
dattoman_1000
Posted: 2005/7/28 1:36  Updated: 2005/7/28 1:36
What mods are required to the carbs to run as a boosted setup ?
I'm thinking of putting some more HP into the racecar with a turbo or supercharger and it would be nice to use my existing 40's if I can rather than making new manifolds,etc.
Demojob
Posted: 2005/7/28 2:14  Updated: 2005/7/28 2:14
I'm pretty sure you just need bigger jets to run a boosted setup and decompression plates etc.
but I think you would need some sort of rising rate fuel reg that way fuel goes up with air pressure.
How have you done your fuel system kegs??
cheers
damo
sidedraught
Posted: 2006/2/24 12:32  Updated: 2006/2/24 12:32
I know you have had your ups and downs with this setup, but it still looks hot.
kegs
Posted: 2006/2/25 0:24  Updated: 2006/2/25 0:24
thanks sidedraught, i would trade all the looks in to have the motor running properly ....
