Main : Members : kegs engine mock up
[<   Previous  88  89  90  91  92  93  94  Next   >]
engine mock up
engine mock upPopular
SubmitterkegsMore Photos from kegs   Last Update2005/7/19 9:53    Tell a friendTell a friend
Hits2480  Comments9    0.00 (0 votes)0.00 (0 votes)
my inlet setup and exhaust, turbo and piping, getting it all tigged next week.
muppet
Posted: 2005/7/19 12:57  Updated: 2005/7/19 12:57
Quite a regular
 Re: engine mock up
Are those Delortho's with the standard manifold? Because my air box has more clearance than that, but I have a 120y With a very similair set up.
You going to run a intercooler with that set up, as I would recommend a 84-87 Mr2 intercooler, fits nicely behind the front grill and has connections on the same side so makes it easy to connect up, well it did with my 120y.
kegs
Posted: 2005/7/19 13:30  Updated: 2005/7/19 13:30
 Re: engine mock up
no its a redline twin weber manifold, only has little clearance coz the air box is fiarly thick, also im not running an i/c just water injection......
evilsim
Posted: 2005/7/19 14:39  Updated: 2005/7/19 14:39
 Re: engine mock up
looks great kegs! any chance the rubber gaskets between the webers and your manifold are going to leak under boost ?? this is gonna be one interesting setup once its done, t'will definitely be worth a drive to your neck of the woods when its done to perv and admire !!
WhiteSedan
Posted: 2005/7/19 15:05  Updated: 2005/7/19 15:05
 Re: engine mock up
tidy looking setup there, should go like #### off a shovel with the twins and turbo. Sweet
datrat_dave
Posted: 2005/7/20 10:08  Updated: 2005/7/20 10:08
 Re: engine mock up
Sweet looking setup dude, what comp ratio you running now? different internals?
Dave
kegs
Posted: 2005/7/20 11:27  Updated: 2005/7/20 11:27
 Re: engine mock up
perv and admire, why not a perv, and a ride !!!
im sure its a chance they may leak, but it would be no different to stock setups that use dodgy rubber boost piping, still has same pressure....
in regards to compression, its about 7.5, 8.0 to one, they are just dished pistons all balanced internals from front pulley to clutch plate still a while off yet. ill have a few more pics in a week or two when my piping is all tig welded.
kegs
Posted: 2005/7/19 11:16  Updated: 2005/7/19 11:16
 Re: engine mock up
u cant see it from this photo but the airbox has about 2 mm clearance !!!!
i had to jack the engine up to get it on. i think im going to put spacers on the engine mounts to roll the engine slightly.
bobs1200
Posted: 2006/2/25 6:42  Updated: 2006/2/25 6:42
 Re: engine mock up
? are you going to seal the vents on the top of carbs and aplly eqaul pressure to float chambers
kegs
Posted: 2006/2/25 9:09  Updated: 2006/2/25 9:09
 Re: engine mock up
bob, if you go to my album and look at the pics where the engine is all finished ull see all the hoses and connections on the tops of the carbies.
