Main : Mechanical : Engine a13 race engine head combustion chamber
[<   Previous  2834  2835  2836  2837  2838  2839  2840  Next   >]
a13 race engine head combustion chamberPopular
Submitterda-feralMore Photos from da-feral   Last Update2002/12/19 22:15    Tell a friendTell a friend
Hits7769  Comments9    0.00 (0 votes)0.00 (0 votes)
40mm Titanium inlet valve 35 Titanium exhaust valves 20cc chambers. Fire groove from plug. Incorrect plugs fitted
killer1200
Posted: 2005/4/19 13:13  Updated: 2005/4/19 13:13
 Re: a13 race engine head combustion chamber
Are they nismo valves ?
LAGWAGON
Posted: 2005/4/19 14:07  Updated: 2005/4/19 14:07
hey feral, you got a car to put it in?? i have a 1000 coupe race only car that could go alright in improved production with a motor like that
COUP1200
Posted: 2005/4/20 0:56  Updated: 2005/4/20 0:56
Hey Feral you show off.
Show us a current picture of the head it looks much better
ridman
Posted: 2002/12/30 12:56  Updated: 2002/12/30 12:56
i have a head like that on my 1200
da-feral
Posted: 2002/12/29 6:04  Updated: 2002/12/29 6:04
The block has had steel main caps made to allow bigger ARP main cap bolts to be fitted for higher RPM operation. The caps were then tunnel bored to suit the block. It uses Nismo light weight lifters and has larger oil return galleries. The inside of the block casting has been de dagged and all fluid flow openings or junctions have been radiused and flow path improved.
Cheers
Feral Errol
dattoman_1000
Posted: 2002/12/20 10:29  Updated: 2002/12/20 10:29
I thought my 38mm inlets and 33mm exhausts were big.
I run 24cc combustion chambers.
Wonder what block mods are done and what the bore diameter is ?
da-feral
Posted: 2002/12/29 6:05  Updated: 2002/12/29 6:05
P.S. Bore is 76.8mm
Cheers
Feral Errol
dattodude
Posted: 2002/12/29 7:04  Updated: 2002/12/29 7:04
It's a nice engine. If I had a third 1200 for an authentic racecar rebuild, I'd think about offering you some cash for it. But commonsense tells me it's time I got my current projects finished. It's time my garage had more running cars than project cars..
I was reading about this engine on your company website. Thanks for sharing the info on it.
Cheers.
Chris Shoesmith
da-feral
Posted: 2002/12/29 20:43  Updated: 2002/12/29 20:43
Chris,
I believe this is about the same spec they ran the 1200's in at bathurst in the 70's, but without titanium rods and valves.
Cheers
Feral Errol
